Question about Nailers 3 12" Pneumatic Air Round Head Framing Nailer Nail Gun
My craftsman framing nailer has two nails jammed in head. Is this something I can repair myself?
  • 2,100 Answers
Yes, just disconnect the air line and get in there and dig them nails out, don't wait for somebody else to work on it. Do it yourself. The front of that gun should lift up and expose the nails coming through, pull them out with pliers, make it clear, then reload and fire it back up and see what happens, a lot of times the generic nails will clog up.
Posted on Oct 10, 2010
Ridgid r350rhd-round head framing nailer the nail is jammed in backwards behind the push rod. don't ask me how it is backwards
FYI The fact that you've managed to flip a nail in the nose can suggest a nail that's too short. Rule of thumb is that framing tools use from 50mm (2") up.
Sep 20, 2013 | Ridgid Full Round Head Framing Nailer...
Nail jammed
You may have to disassemble the front end or at least take the magazine feed off to get it out
Nov 23, 2012 | Dewalt D51850 Heavy Duty 20 Degree Full...
Common problems dewalt clipped head framing nailer
there is NO easy solution for this, but unplug air and get a pair of safety glasses and a punch and try and knock the driver up into the tool away from the nail or if it is just jammed try and pull the nail out. You didn't really specify where the problem is. Let me know if you need more assistance.
Jan 05, 2012 | Dewalt D51822 Clipped Head 2Inch to...
Nailer will get two nails jammfrontiered at same time about every 3rd nail
Nail jamming is caused when the driver is able to hit two nails with one stroke. This usually happens on nailers that use nail strips with no spacing between nails. If the driver is damaged, it may be able to hit part of the second nail. If the wrong nail is used and two nail heads are in the path of the driver then jam. On nailers using nailstrip with space between nails, it is much harder for driver to hit two nails. Most jamming, however is caused by the nailer actually firing twice in very rapid succession. this type of jam is caused by faulty firing mech. (safety foot or bump fire system) , faulty/worn trigger valve or worn orings in the headvalve .
Sep 16, 2011 | Stanley Bostitch Coil Framing Nailer
I have a FC350A FRAMING NAILER, IT IS IN THE
check to make sure that there is not a nail jam , if the driver will not retract then the gun will not cycle . if no nail jam then replace the inner trigger
Feb 02, 2010 | Air Tools & Compressors
I have a craftsman nailer full head framing gun. There is a jam of 2 nails in the cylinder. How do you unjam the gun
On that nailer, you have to remove the nail Magazine. And then clear jam thru the sloted open side. And then put the Magazine back on. Usually one big bolt on each side of the nose and 1 or 2 bolts on the rear body.
Aug 25, 2009 | Air Tools & Compressors
I have a Sears framing nailer that uses clipped head nails.
I know on some other brands that to convert them we had to change the noses, but I honestly don't know about Craftsman. If you give me the model number I will try and do some more research and possibly come up with a tech support number for you.
Nailer drives one nail but driver pin doesn,t retract back into nailer head
Remove the air hose and open the nailer head section. Look for a foreign object in this are that could be jamming the drive pin. Also, make sure you are using the right size nails.
Jul 11, 2009 | Craftsman Nailer Kit, Palm Air Driver
Is there any way to free driver blade on nail gun? my gun is the dewalt 20 degree framing nailer
I am assuming that a nail got jammed? If so unplug air to tool, remove the rest of nails and turn it over. try to find a flat piece of steel smaller than the nose where nail goes and gently tap the driver back up and remove jammed nail. If the driver is broken that is a different fix. Hope this helps
Dec 06, 2008 | Dewalt Round Head Framing Nailer D51845
Nailers 3 12" Pneumatic Air Round Head Framing Nailer Nail Gun Logo
193 people viewed this question
Top Nailers Tools & Hardware - Others Experts
John Trevino
Jim Hensey
Level 1 Expert
Paul Lettieri
Paul Lettieri
Level 1 Expert
Are you a Nailers Tool and Hardware - Other Expert? Answer questions, earn points and help others
