Question about Verge DFP-200 MP3 Player
Help! Power saving feature shutting me down
Is there any way to reset/disable the power saving feature that automatically turns off after the player is idle for 3 minutes??? Thanks! Marna
  • 8,596 Answers
There is not a way - sorry - the only adjustable is the backlight feature
Posted on Jul 06, 2008
Tv keeps shutting off
hi deborah.
not sure if this will help you out,if not go to the link at the bottom for more help.
If you don't hit a remote button for a few hours, the TV turns itself off. Check to see if there's a settings option to disable this power saving feature, or to extend the time before it automatically turns the TV off. Maybe a sleep timer setting? The sleep timer is off.
Tv keeps shutting off Google Search
Nov 06, 2017 | Televison & Video
After viewing for 2 minutes my TV automatically shuts down. Sometimes I get a pop-up screen that says "Disconnecting anynet + device. How can I fix this?
One of the options in the TV setup is to allow other components like DVD players to control via the HDMI cable the power turn on and off of other components, The feature is available for all any-net complaint components,
This allows for when you power up the DVD player the TV comes on at the same time. And when you power down the DVD player the TV goes off. At times this feature can create confusion.
Suggest you go into settings on the TV and disable/off the any-net+ feature.
Under this set up the TV will need to be turned on/off separately from the other components. Also the video input will be needed to be selected. In this setting other components.can no longer control the TV.
Nov 27, 2015 | Televison & Video
Power problem
If the protect function works but is causing you problems, cancelling the protection function should help, and it will be possible to enter the self-diagnostic function mode. This should disable all functions of the protection mode, excluding the 'excess electrical current detection' feature.
While pressing the "Tone Control" and "Info" keys, try pressing the power key to turn on the power. Keep pressing those 2 keys for 3 seconds longer.
this should activate the Self Diagnostic function, with your Protection Mode disabled.
in this mode the 'sleep' section on the tv's fluorescent display flashes to indicate that the mode is properly activated.
just be very aware, this function is normally there as a safety feature and i cant guarantee that disabling it altogether won't cause other problems down the road. best of luck!
Jun 06, 2014 | Yamaha Audio Players & Recorders
Toshiba tv automatic on off
Depends on the model. Some models have energy saving feature
The unique energy saving feature is called 'Automatic Power Down'. This means the television will self-switch into stand-by if no television remote control commands are received within 4 hours. This feature is an energy saving solution for situations where the television may be left unattended for extended periods and has been enabled as the default setting.
You will see an on screen warning prior to the automatic shut down. Automatic shut down will be averted by depressing any key on the television remote control.
Use of automatic power down functions will be progressively introduced to future models in an effort to reduce energy consumption and greenhouse gases.
If you would like to disable this feature you may follow the instructions below (depends on TV Model)
1. Press theMENUkey on the remote control.
2. Press theright arrow keyand highlightSETUP.
3. Press thedown arrow keyand highlightAutomatic Power Down.
4. Press theright arrow keyto change setting toOFF.
5. Press theEXITkey on the remote control.
Some models "auto shutsdown" if it doesn't detect any signal from the TV for around 15mins. Please search for this setting in the user's manual.
I hope it helps!
Jan 23, 2014 | Toshiba Televison & Video
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
Elements Mp4 player shuts down after little play
Mine did the same thing. What I did, and it worked well for me, was I went down the menu until the Settings, then clicked that and went down until the Power Off section. I clicked that and went to Sleep Time, and held the right button down until it was set to 240 (I think that's what the highest # is). That keeps it playing for 240 minutes, after which it automatically shuts down to save power. You have to reset this every time you turn the mp4 player back on.
Hope that helped!
~~*Holly*
Jan 09, 2009 | Audio Players & Recorders
Automatically retarting when I shut down computer
2000 Is Windows 2000. Why did you put that disk in? Did you start loading Windows 2000 or XP Pro, XP-Home?
It sounds like your switch is wired to the reset jumper on the motherboard or you are hitting reset.
Tell me what the computer screen has on it before it shuts down please.
I will wait on you answer. Do not rate until we are done.
Jun 10, 2008 | Computers & Internet
Nothing appears on the LCD screen. What should I do?
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode. When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Verge DFP-200 MP3 Player Logo
46 people viewed this question
Top Verge Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Verge Audio Player and Recorder Expert? Answer questions, earn points and help others
