Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE bottom refrigerator model PDS20SBSALSS. It goes into a mode where it starts clicking like a small relay turning off and on. While it is doing this the cooling shuts down and everything gets warm. It will reset it self and start working fine and then for no apparent reason it starts all over again. The temperture display is incorrect while it is doing this. The unit is three and a half years old.
    Sergeant:
    Champion:
  • 351 Answers
Hi that may be the relay on the compressor pull the refrig out listen around the lower back where the compressor is if you dont hear it there there is a computer a little higher that maybe bad making the sound jim
Posted on Oct 10, 2010
GE Profile - model PDS20SBSALSS - constant clicking noise
The clicking is the compressor trying to start. If the compressor is extremely hot, try allowing it to cool. The condenser fan should run even if the compressor is out on overload; that may be the cause of the compressor failure. Check the supply to the fan and replace it if it doesn't run.If the compressor has been overheating for some time, it may be damaged and also need replacing.
Jun 13, 2012 | GE Refrigerators
My ge fridg model PDS20MBSWW has a problem: many times a day it make a clicking noise the control light goes out and after 30 minutes everything return to normal can you help thanks
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 21, 2011 | GE Profile PDS20MBSWW 30" 19.5 Cu. Ft....
Hello I have a GE lower freezer model # PDS22SBSARSS AND THE TEMP CONTROL is clicking and the digital readout is doing weird things by indicating wrong temperature and clicking, it stops after awhile...
Roll the refrig out and determine where the clicking noise is comming from. If it is form the small rectangular cover on back, replace the main board (WR55X10942) located under it. If the clicking is comming from the compressor area (at the very bottom, behind the cover which goes all the way across the bottom of the refrig) then replace the relay (WR07X10086) and overload (WR08X10061) located where the wires attach to the compressor, and for good measure, the capacitor (WR62X79 ). (located just to the left of the compressor)
Jan 12, 2011 | GE Profile PDS22MHR Bottom Freezer...
Have a GE Profile bottom-freezer refrigerator, model #PDS22MBSBWW, serial #RL053351, approximately 5 yrs old. It has recently started making a "clicking" sound which goes on for anywhere from 1...
For the clicking if the fridge has been off for at least 5 min. and clicks when it tries to start then it may be the start relay on the compressor . If it does not stay off for at least 5 min then it may be the control which may also be why your display is not working.
Nov 30, 2010 | GE Profile PDS22MBS Bottom Freezer...
GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Apr 09, 2010 | GE GDS20SBS Stainless Steel Bottom Freezer...
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
GE profile bottom freezer refrigerator clicking
Your relay on the compressor is bad. It is called a PTC relay they are known to go out.
First be sure to unplug frig. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Jul 05, 2009 | GE Refrigerators
GE PROFILE BOTTOM FREEZER PDS20SBSALSS Digital temperature reading for freezer rising. outside of compartment very warm. Fridge temperature now 44, Freezer at 12. Settings have not been changed. quick...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 02, 2009 | GE Profile PDS20SFSLSS Stainless Steel...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
