Question about Samsung TruDirect SpeedPlus DVD-RAM Burner
Trudirect speedplus. New computer. Itunes wont play or import a cd but media player works fine? Checked upperfilters in registry - all fine? Any ideas?
  • 428 Answers
If you are not working in Mac OS environment, itunes may not play. usually Mac, owner of itunes overly protects it.
Posted on Oct 10, 2010
I downloaded formware for my Trudirect Super writemaster but now the burner won'y even work...playing or burning. What do I have to do to rollback to the way it was? I have two burner players,
The firmware update did not take and rendered your unit into a useless paperweight. Happens. That is why, often, if something is working fine, it is best to leave it alone rather than take the risk of some thing going wrong. Lesson learned.
Jun 12, 2017 | Samsung TruDirect SpeedPlus DVD-RAM...
My samsung trudirect dvd writer is not shown on mycomputer. please help me soon. thank you.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 06, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
When i put a cd in my cd/dvd rom it wont play dvd movies nor cd's, it wont show the dvd movie in windows media player nor itunes nor quickplay. the rom says dvd rw-r and those are the dvds i play and...
Try to run the following hyperlink
Hyperlink to microsoft automatic assistance
Hyperlink to Cd drive autofix
If it doesnt work then try following steps:
  1. loadTOCNode(2, 'resolution'); Click Start, and then click Run. (in case of windows 7 click start, look for search program and files , type in there regedit and hit ok, jump to step 3)
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  1. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click
    UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  2. On the Edit menu, click Delete.
  3. When you are prompted to confirm the deletion, click Yes.
  4. In the right pane, click LowerFilters. (dont panic if you dont see lower filter)
    On the
    Edit menu, click Delete. (or simply right click and select delete)
  5. When you are prompted to confirm the deletion, click Yes.
  6. Exit Registry Editor.
  7. Restart the computer
Apr 20, 2011 | HP DVD DRIVE DVD Drive
Samsung TruDirect SpeedPlus DVD-RAM Burner can't see any DVD/CD when BURN, but READ still good. HELP me plz
make sure all leads that are attached to your drives cd/dvd, 3 1/2 inch floppy have secure connections and are not faulty
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 07, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
Super Write master Samsung TruDirect SpeedPlus
the CD ROM cannot display the content of the CD. Give me the best solution please.
Oct 20, 2010 | Samsung TruDirect SpeedPlus DVD-RAM...
Code 10 no cd/dvd drive found, unable to burn cd?
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Jun 24, 2009 | Apple iTunes
Hi, l noticed just recently when I insert a CD into my Dell Laptop (Latitude d810) that the system does not acknowledge, open, play this cd at all. I've tried various CD's: copied and originals and I have...
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
If you cannot access the CD or DVD drive, or if you receive an error message, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions to the problem.
source:http://support.microsoft.com/kb/314060
Jan 09, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Media player
first thing you do check your sound driver may you mistakenly uninstall it because if the sound driver has been uninstall it will not work after that you can still check you drive if it install very well
Jun 12, 2008 | Gateway GT5220 PC Desktop
Error 2131
try this:
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
Step 4: Restart the computer loadTOCNode(3, 'resolution');
Jun 06, 2008 | Computers & Internet
Vostro laptop dvd/cd player not seen by system.
1.go to bios by pressing f2 key on dell logo
set num lock caps lock scroll lock on
press alt + e
press alt + f
press esc twice
2.
Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Mar 14, 2008 | Dell DVD-rom DVD Drive
Samsung TruDirect SpeedPlus  DVD-RAM Burner Logo
159 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
