Question about HP Pavilion Slimline S7410N Notebook
The wheel and rubber belt came off door wont open now how do i get it apart to fix it
  • 428 Answers
Go to http://h10032.www1.hp.com/ctg/Manual/c00877796.pdf to download the service guide/maual so you can take it apart an fix the problem.
Posted on Oct 10, 2010
Door won't open to release video disc
The rubber belt that turns pulley to open door may need replaced. I had 4 dvd players do the same thing I bought the rubber bands that kids use to make wrist bracelets sense I couldn't find replacements. The rubber bands opens dvd tray just fine now its a cheap fix if that"s your problem. The the rubber belt is located at front of player inside on top where dvd tray comes out.
May 18, 2015 | LG Televison & Video
Philips mcm298/37 doors wont open
If the acrylic door will not open, give it a nudge with your finger.
If it opens with the nudge the solution requires taking the unit apart and replacing the door actuator drive belt.
Mar 05, 2013 | Philips MCM298/37 Shelf System
I cannot open the right tape deck door.
The mechanical section in the drive need overhaul - belts, idlers, and all rubber parts are either slipping or broken. Take it apart and check the belts.
Nov 08, 2010 | Onkyo Audio Players & Recorders
The door wont open on my xbox 360 how can i fix this without having to pay money for an eguide. To me that is just crazy. I know how to get the machine apart. I am just stuck as to how the door will open...
It's the belt... you need to replace the belt inside of the DVD drive. It wears out and will be no longer strong enough to pull the hub/motor away from the top magnet so that the tray has space to open. Replacing it with a new belt solves this.
Do you know if you have a Samsung, Hitachi, or other drive in there? This is most common with the Toshiba/Samsung drive and you can find the belt at the following website:
http://store.richspsxparts.com/rebeforxb360.html
Oct 21, 2009 | Microsoft Xbox 360 Console
Error 0306 same here
A few things you might want to check (if you're willing to take your unit apart):
One possibility is a faulty door open/close knob on the front panel (this is probably a soft touch micro switch). Check for electrical continuity when pressed. If it needs to be replaced, you can use one from a scrapped CD/DVD-ROM unit, just make sure it's of the same type, otherwise you can get it on ebay or from manufacturers like Switchcraft, Piher, etc.)
If the unit has a belt driven mechanism for opening the cd door (also called the cd tray unit), see if the rubber belt is broken or has lost tension - in such case the drive motor is not able to open the door. If this is, in fact, the case, you'll need to replace the drive belt.
You need to find out its diameter, standard sizes can be found on ebay, just use the nearest standard size that is slightly smaller than your old drive belt (an old belt gets slightly oversized and that's exactly what causes it to loose its drag power).
Some mechanisms have a plastic wheel with a rubber edge which is driven by torsion from a motor - see if the rubber is greasy, damaged or dusty (you can clean it with some alcohol), but a replacement for these may be difficult to obtain since it's probably a brand/model specific part.
Then there are also mechanisms that are driven exclusively by gears (check gears for any broken teeth, also, the motor could be the problem). These are, again, brand and model specific parts and may be hard to get.
Another thing to check are the door open/closed switches. These are a pair of metallic contacts somewhat alike to a relay contact. They are usually located somewhere underneath the tray, possibly near the front end. See if the metallic contact points are dark with oxydation, if so, clean them by smearing them gently with a piece of fine sandpaper (be careful not to damage them, they may have a clear plastic cap-arm that needs to be removed prior to cleaning). There are usually two sets of such contacts in each tray unit, one for door open signal and one for door closed signal, so check both of them.
You can test the door motor by disconnecting it and running it of a 3 to 4,5 volt battery. If the mechanism is ok, the tray should open on one polarity and close when you reverse the battery poles (don't force it though, just run it for a few moments so that you see if it works fine).
From here on the things to check are motor connectors (any broken wires or bad solder contacts?), drive IC's, electrolytic condensers associated to the door motor drive section on the main circuit board.
So, there's quite a bunch of things that might cause the problem, also, could be that the true cause is something else.
Anyhow, i hope you can find out what the trouble really is and fix it.
regards
3rq8 (Triarcuate)
Jul 25, 2009 | Sharp CD-BA200 CD Shelf System
Door on left side wont open
not much you can do about this. I've had mine apart and it seems the belt (rubber band-like) are weak or stretched. This is a weak spot on this unit.
Jul 03, 2009 | Sharper Image SA260 CD Shelf System
Seat belt wont move
you probably need to be mechanically inclined to fix this problem. When the shoulder strap stopped working on mine the switch that is operated by the door latch had to be serviced. ie: the door will have to be taken apart to access the switch.
Jun 17, 2009 | 1987 Toyota Camry
Rio HT2030 disc loader will not open
I have had the same problem. There is a rubber ban that acts as a drive belt to open and close the disc loader. i took the cover off and then the disc loader cover off to expose the bubber ban. Then i replaced it using two rubber bans from my daughter's braces and reassembled. Works great again.
Dec 23, 2008 | Rio HT2015 DVD Player / VCR Combo
Broken Magnavox 5 disc changer
old is always gold... just follow some tips as i say... open the player with the door ejected clean the lens wit the dry cloth and clean the dust particles in it especially near the rubber belt connected to the dc motor... after that try to play cds it will play...
Feb 06, 2008 | Audio Players & Recorders
Open Questions:
HP Pavilion Slimline S7410N Notebook Logo
62 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
