Question about Canon imageRUNNER 5570 Copier
I have ir5570 copier. I am having problem during starting step. If I do power on machine doesn't coming opearation mode. Messag code is E000002-0010. Please anyone can give the solution. Thanks Insan
  • 134 Answers
SOURCE: E000002-0010
This is a fuser error, which has to be reset in maintenance mode by a technician.
Posted on Apr 15, 2010
  • 149 Answers
SOURCE: my copier prompt an error code e0602. what seems
there is one thing you can try to get it back up and that is to hold down the 1&9 keys while turning the main power switch on... this will start a scan disk mode and you will see a little white block start in the upper left corner of the screen and start to drop. it should take approx 20 to run its test. now if for some reason that doesn't work then you will need to have the HD replaced and have the system software reinstalled.
Posted on Jun 23, 2010
  • 170 Answers
SOURCE: canon clc 3220 E000002-0010
try to reset the error just enter the simulation program press *- 2,8(simultaniously)-* select copier- select function- select clear- select error- press ok then turn off/on the machine
Posted on Nov 20, 2010
  • 170 Answers
SOURCE: hi every one.i have canon copier ir105 gives me
maybe the dc controller is also need to replace or try to reset the error first to reset the error code press * 2&8 simultaniously,* then select copier, then select function, then select clear, then select error, then press ok & turn off & on the power switch
Posted on Nov 22, 2010
  • 71 Answers
SOURCE: Please I have canon copier IR3170C but it has been
getfile.asp?rid=1258 May 8, 2006 getfile.asp?rid=3215 Product : imageRUNNER C3100 / C3170 Title : E021-000x Error Code Error :
E021-000x Error Code: Developing rotary does not rotate and abnormal noise comes from motor.
E021 can be displayed when an error occurs in the developing rotary.
The detail codes are:
0001: The developing rotary home position cannot be detected.
0002: The intervals of flag detection during rotation is too short or long.
0003: The sensor does not detect the flag when the developing rotary stops at development point
As a result of inspection, it was found that the DC Controller PCB was unable to control the motor because it was faulty.
Workaround :
1. Check whether or not the developing rotary receives any physical load.
Rotate the developing rotary in a counterclockwise direction by hand to see whether it rotates smoothly. If any abnormality is found, eliminate the root cause. No problem is found, go to the Step 2.
2. Make sure that the connectors are securely fitted between J313 on the DC Controller PCB and the Rotary Motor (M8) or there is no pinched wire. No problem is found, go to the Step 3.
3. Replace the DC Controller PCB with a new one. If the symptom still recurs, go to the Step 4.
4. Replace the Rotary Motor with a new one.
DC Controller PCB: FG3-3846-030
Rotary Motor: FM2-0080-000 Canon USA, Inc. Systems & Technical Support Division
Posted on Jan 24, 2011
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Dec 20, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Canon ir5570 error code e000110-0001
Hello crystal... on ir5570 error E000110-001 indicates that the polygon motor is not functioning and must be replaced. Joe
Thanks for choosing Fixya!
Mar 10, 2011 | Canon imageRUNNER 5570 Copier
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
E0004-103
This problem is caused by the fuser unit that fuses the ink to the paper. You will need to reset the service error in the service mode before the code will be reset. The procedure for resetting the service error is in the manual but is entered by pressing the * 2+8 buttons together and then * again. Then select FUNCTION - CLEAR - ERR Then exit service and turn the machine off and on and the code should go. If not then replace the thermistor suggestedin the manual for such codes.
You can find the ir5570 service manual here.
Aug 20, 2010 | Canon imageRUNNER 5570 Copier
Every time I start the machine the f1 error comes up within a few seconds. have to press pause & start about 3 times & it will finally start to work. have to do this several times during the entire...
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^@#$%
Jun 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
ON SWITCHING ON THE COPIER KONICA 2020 ERROR CODE F35 DISPLAYS PROMPTLY
How to clear fuser abnormality codes (F34, F35, F36), 2020.
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
If the code comes back then your fusing unit will need parts/service.
Dec 14, 2009 | Office Equipment & Supplies
ERROR E840 FOR CANON IR5570
This is a fuser shutter error. Subcode 0001 is that the shutter is not being detected by the shutter sensor. 0002 is that the shutter is moving but on/off detection timing is off. When the copier is powered up you should here this shutter trying to find the home position. If the error occurs then, most likely the sensor is bad or unplugged. Have you done any fixing repairs recently and got this error?
Nov 04, 2009 | Canon imageRUNNER 5570 Copier
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Ir5570 losing network connection on sending only
Is your firewall on the router or on the server? Are any of your computers using Windows firewall, McAfee, or norton security software?
Oct 06, 2008 | Canon imageRUNNER 5570 Copier
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Canon imageRUNNER 5570 Copier Logo
160 people viewed this question
old marine
old marine
