Question about Bose SoundDock Digital Music System for Apple iPod - White
Bose Sounddock - Speakers have a loud hiss at low song volume
Makes a "white noise" type sound at low music volume, or when ipod docked but not playing.
Only noticable at low volume. Sound is high pitched, and has popping elements.
  • 12 more comments
  • Anonymous Jun 18, 2008
    same here!
  • david-baxter Jun 21, 2008
    i have same problem is like a whistling sound, it seems to only happen though when my ipod is fully charged in the dock, if the battery has run down a bit and i dock it then i dont get the noise
  • jcstone44 Jun 22, 2008
    i have the same problem.. it sems louder when its plugged in but not playing.
  • write2tum Jun 30, 2008
    I also have the same problem, and it also seems to hiss once the battery is fully charged and ipod is not being played, when ipod is played, it tends to go away most of the time (unless i press forward/backward song, it comes back from time to time). Is there anyway to fix this?
  • davidwross Jul 06, 2008
    I have a very similar problem with ipod touch! It sounds like a helicopter on low volume interupting quiet sound passages, and is there whne the ipod is connected and even switched off. Sounds OK through the headphones though... Tried resetting the ipod to no avail. Next stop Bose store with said ipod for answers.
  • JohnWGreg Aug 04, 2008
    I have the exact same issue. Hissing, humming, helicopter noise when soundock is at low volume. Seems louder when ipod is paused but I'm thinking that this is just because the music is not slightly drowning out the hiss. Has anyone solved this problem?
  • caroleas Sep 16, 2008
    I am glad to see I am not the only one with this problem...I was beginning to think my Bose Soundock was cursed. Same high pitched frequency sound when iPod played at low, low volume (e.g. in my cubicle at work).
    Very annoying because I'm the only one who can hear it.
    Any solutions?
  • jonny lad Sep 24, 2008
    i have noticed the same thing, but i noticed when the light on the ipod is illuminated, (it comes on when you pause it or change track) the whistling stops, but when after the time lapse it turns off, the whistling starts back up! i think the whistling is always there, its just that you can hear it when the volume is down.
  • Anonymous Nov 22, 2008
    so does any one have an actually answer to the problem, mines being bareable for a while but doing my work at nite and needing the volume low its making the noise very anoying i have heard its just sumthing they do but am hoping for £250 it aint a standard fault,
  • Anonymous Dec 09, 2008
    Bose people are useless. I took my speakers back to get fixed with this exact problem, three weeks later I got a call saying they were fixed and ready to be picked up. I gave them a blast when i got home.. still just as bad!
  • Anonymous Dec 19, 2008
    The same with me! My Bose-Sounddock has a very high frequency hiss. Unfortunately I do not know who to blame? Is it appels fault and the Bose speakers are just too good (removing the ipod mutes the hiss)? Or is Bose **** too?
    Btw. I realized, that the frequency changes if the ipod is charging battery or not...
    Any solutions?
  • Anonymous Feb 08, 2009
    loud hiss when any ipod is in the doc
  • stevo_mcfc Mar 14, 2009
    so , does anyone know what the problem is or know how to fix it? It's doing my head right in!
  • Anonymous May 03, 2009
    Soundock hisses when iPod connected. It's worsening. I occasionally lose sound altogether. Any fixes?
Here is how I fixed the hissing noise in my Soundock;
--Pull the bottom plate off (It is attached by 4 screws)
--There is a green motherboard with 2 ribbonwires. .
--One of the ribbonwires (the one the mounts the ribbon vertically) had loosened up.
--Use a tweezers to pop it back into place and that noise will disappear.
This is a design flaw, as the action of inserting/removing your ipod, coupled with the action of setting your sound dock down will work this ribbon loose.
Posted on Aug 21, 2009
  • Johnfen Dec 04, 2010
    i think i see the two ribbons but i don't see where it has come detached. is there anymore help you could give? do i need to take the three screws out (weird screw heads) that are at the bottom of the ipod dock connector? thanks so much
This totally worked for me:
Posted on May 27, 2010
I had the same problem, clearly bose knew about it, seems to be a problem with the power adaptor interfering. they sent me a new power pack and voila it is now totally silent.
Posted on May 02, 2009
I had the same issue with very annoying high frequency "white noise" with my SoundDock® Series II. As per other comments, this noise was more audible at low volume and in between tracks and the frequency of the noise varied depending on whether my ipod Classic was connected, how bright the back light was, whether it was charging etc. I eventually pin pointed the noise down to the power adapter (try putting the transformer close to your ears with the base unit as far away as possible). I spoke with BOSE UK technical support team on 0870 741 4500 who were extremely helpful. Apparently this was a known issue with the Series I but not so with the Series II (they have different power supplies). Whilst the noise originates in the transformer some noise will be evident through the speakers which is why it was difficult to identify the source of the problem. As the unit was within warranty (2 years in the UK) I took this back to Comet and had a new power supply within 5 days - excellent customer care. Replacement power supplies can be purchased from BOSE spare parts department using the above number. Hope this helps as the sound quality on this unit is exceptional - now there is no interfering background noise!
Posted on Jul 30, 2010
Me too
Posted on Oct 17, 2008
    Problem Solver:
  • 17 Answers
If you wanted to fix it you can look at ridax pcbs, but there a littleover $50+ for the part. But I'm currently buying broken sounddocks, so if youwant to sell it contact me at
Posted on Apr 10, 2009
Ipod classic 80GB makes a horrible popping noise with sounddock II
Sounds like there might be a loose connection between your iPod and the dock. Firstly make sure there is no dust or grit inside the female 30 pin of the iPod. Also make sure that there is no grit or dust around the male end on the dock. If there is grit or dust (or even if there isn't, some compressed air (you can buy this in a can) will help to clean out the connection. Also make sure that when you dock the iPod, it is seated on the dock properly. You should be able to see if it isn't seating properly. If this doesn't fix it and you are near an apple store, I would recommend taking the problem to them where they will be able to make sure that the iPod isn't causing the problem.
Nov 30, 2013 | Bose SoundDock Digital Music System for...
Speakers bose docking station make a noise
Have two Bose docking stations and the oldest (white) one have some problems now. When I put in one of my iPods in the docking, the speakers make some weird, creaky noises. Kind of a sound, when I'm looking for a channel on the radio. When I wiggle a little bit the connector from the docking station, it will play some music for a short time. Still it is not the same quality sound, it used to be. Also, some times the sound is too loud and when I touch ONE time the volume minus (-) button, you can hardly hear the music, it is too soft. Hope somebody can solve this problem.
Sep 10, 2012 | Bose SoundDock digital music system...
No power to ipod when siiting in the sounddock just ticking noise from speakers with or without the ipod sitting in it
You have a wrong type docking board fitted - check you have the right board type. If someone has replaced the docking board with the wrong type then this happens OR there has been a drinks spill in the docking area. About 2 ticks a second. Contact www.invebo.com for a new board or a USB upgrade kit to get your dock to charge the Iphone.
Aug 08, 2010 | Bose SoundDock Digital Music System for...
Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Dec 09, 2008 | Bose SoundDock digital music system...
No sound
Try other iPods, if they give you sound it's a problem with your iPod, if not then check to make sure you are using the right plate by removing the insert and try the iPod without it. Otherwise contact Bose.
Dec 03, 2008 | Bose SoundDock digital music system...
Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Sep 17, 2008 | Bose SoundDock digital music system...
SoundDock produces only harsh crackling sound
Yeah i had that same problem. You know the chord? The cord you plug in from outlet. The square cord you plug into your speakers.. yeah the "DC outlet" is supposed to be UP. if you have it the wrong way in there it wont work and will make a crackling sound.
Apr 30, 2008 | Bose SoundDock Digital Music System for...
Bose SoundDock Digital Music System for Apple iPod - White Logo
5,963 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
