Question about Kenmore Dryers
Should the thermostat have a rattle to it when I shake it. part no 3387134
2 Suggested Answers
vostendorp
  • 347 Answers
SOURCE: Kemore dryer model110.67522600,
Both the high limit thermostat #3977767 and the operating thermostat #3387134 are normally closed switches and should have continuity. These thermostats are usually replaced as a set because when one fails its often caused damage to the other. The part # for the kit is 279816 and comes with both and is cheaper than if bought separate
Posted on Sep 16, 2010
What number thermal fuse and thermostat will work on kenmore elite model 11o 23032 dryer
thermal fuse 3390719
Thermal cut off and high limit kit 279816
Operating thermostat 3387134
Jan 22, 2017 | Kenmore Dryers
Rattle and shake from front to rear of VW
The problem you describe is coming from your suspension .if your having fuel problems and your car is puttering or surging this will cause bad suspension to sound very noisy and make a lot of different shake and rattles
Jan 13, 2014 | 2005 Volkswagen Touareg
I opened the refrigerator and its no longer cold in there, both sides.
Greetings,
The first thing is to determine if the compressor is running...if its off and not running..remove rear cover...if you hear a clicking noise once every five minutes or so...The relay may be bad...this is the part that fits on compressor terminals. remove it and shake it..if it rattles...its bad, it could even be bad and not rattle, but they usually burn out and rattle...okay, now if compressor is cold and nothing comes on..it could be off thru the defrost control or thermostat. I'm betting , its a burned out relay
Jan 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a model LDG712 gas dryer. The flame ignites and burns for about 20 seconds. The flame then stops burning and it about 1 minute and 30 seconds or more before it lights again. The glow bar...
The flame should cycle on for about 50 seconds on the first cycle and approx 20 sec each additional cycle. I would check your airflow out of the dryer it my be restricted not allowing the flame to pull through the burner tube causing the unit to "short cycle". Its not likely a thermostat issue but if you were to replace a thermostat I would replace the cycling thermostat should be part number 3387134. Hope this helps.
_MJ_
Dec 15, 2010 | Maytag Dryers
Kemore dryer model110.67522600, checked continuity on heating element,OK, Thermal fuse OK,cutoff-tml ? Thermostat #3977767 no continuity.Thermostat #3387134 ?
Sep 16, 2010 | Kenmore Dryers
Rattling sound from the exhaust
The metal shielding around your catalytic converter could be rattling or the rubber donut that holds the rear tailpipe could be bad. When your car is cold shake your tailpipe and see if you can reproduce the noise. If you can your tailpipe donut is likely bad. Three dollars at any auto parts store. If it does rattle when you shake your tailpipe then the heat shield for your convert could be loose. You need to tighten it up another piece of metal between it and the converter to keep it from rattling. If you hear the rattle when you go over bumps too then your exhuast is probably, loose. Crawl under there and stake shaking things, I am sure you'll find the problem
Apr 07, 2010 | 2002 Kia Rio
Dryers Logo
606 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
