Stone silent glow heater model - Heating & Cooling
How do you replace the wick in a comfort glow model gr9a kerosene heater?
Post your question on this page , and you shall find the answer .
http://www.searspartsdirect.com/partsdirect/part-model/Comfort-glow-Parts/Heater-Parts/Repair-Maintenance/Questions-Answers/Model-GR9A/0218/0912160?mmlLandingSearch=GR9A&modelNumber=GR9A&diagramPageId=&documentId=
Sep 05, 2015 | Comfort Glow Heating & Cooling
Goodman heater not igniting, coil does not glow. Do I replace the coil and would that not allow the gas to open if there is no glowing coil?
your correct the gas valve will not open ifnthe glow coil does not ignite the flame which then hits a flame sensor (looks like bent piece of wire usally on the opposite side of burners from glow coil) you can with a long lighter thats is used for lighting a gas grill light the furnace manually that will allow it to run through one cycle only. you must first have the door off to the burner area, have someone else turn the furnace up to when it turns the exhaust blower on. when that blower starts running you have to listen for a click , that click is when you will hold the lit lighter right where the glow coil is, the pilot will light and your furnace will run, providing its only the glow coil that is bad. you may show your ex how to do this and leave her do it for the rest of the winter that would help keep her off your back and you could kill two birds with one stone so they say. if you do get a new glow coil i recommend getting the new style they cost a little more but they are not as fragile, you cant touch with hands or bump the old ones but the new ones take a lot to break and seem to last longer. Good Luck
Dec 29, 2011 | Goodman Heating & Cooling
99 ford f550 diagram on how to remove glow plugs
with the engine "stone cold," disconnect battery, remove valve cover, disconnect glow plug connector, remove glow plug with a 10 mm deep socket, install new glow plug (torque to 13 ft.-lbs.), and reattach connector. After finishing the remaining 3 glow plugs on that bank, clean valve cover, install new gasket, and reinstall valve cover. Do the same thing for the other bank of glow plugs and reconnect battery. Not a difficult job--should take several hours.
Jun 14, 2011 | 1999 Ford Super Duty F 550
Where can I get replacement stones for Palermo electric fire? made by Dimplex thanks
The model you listed is only sold in Europe. However, if you live in or near the UK, you purchase the stones from Fires and Fireplaces Direct 085-239-0034 http://www.firesandfireplacesdirect.co.uk/cat-electric-fires.php
Hope this helped you find your stones.
Apr 06, 2011 | Heating & Cooling
When heater is switch on, it glows at one side and continually glows on and off, is it broken?
Is it the ignitor glowing or the heater's ceramic plaques? Also knowing who the manufacturer is and the model number, will be a big help in answering your question.
Mar 23, 2011 | Heating & Cooling
Looking for a Comfort Glow Kerosene Heater Manual. Model #PHS/D
I am looking manual or answers for Comfort Glow Portable Heat System Model PHS/D with serial # 3D006270186
Jan 03, 2010 | Desa International Comfort Glow Infrared...
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Heating & Cooling Logo
290 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
