Question about Mitsubishi WD62527 62 in. LCD HDTV
My TV turned off after a power surge, now a red light over "lamp" is constantly on. When we push the reset button, we can hear sound and then the tv turns itself off after a minute
  • Mitsubishi Master
  • 5,387 Answers
If the Lamp light is steady, the lamp has failed and must be replaced. The TV will not work until the lamp is replaced (and the lamp cover is properly attached). Call (800) 553-7278 to get a replacement lamp from the manufacturer. Order lamp part number 915P028010. Once you have the replacement lamp, make sure that the TV is off for at least 30 minutes before replacing. Avoid touching the lamp glass - it will shorten the lamp life. Unplug the TV and use a Phillips screw driver to remove the lamp cover from the back of the TV (2 screws hold it on the right hand side) . Loosen the two screws that hold the lamp cartridge (one on the bottom left corner and one of the top right corner). These screws will not come completely out. Grasp the handle and pull the lamp cartridge out straight towards you. Place the new lamp cartridge completely into the opening then tighten the two screws that hold the cartridge. Replace the cover and screw it back into place.
If the lamp cartridge or cover are not properly secured, the TV will not come on. (There is a safety interlock).
I hope this helps.
(the lamp should last at least a year; if not, contact the manufacturer for a warranty repair.)
Posted on Oct 10, 2010
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I have a Zenith D60WLCD, I have replaced the lamp and it still will not power up. I there something I need to reset.
You need to reset the lamp counter if it reaches 16,000 hours. The tv will not turn on once this limit is reached. With the tv remote, and the tv off, push the ? Button on the remote, then 9876, then push the enter button. The three lights on the front panel will flash indicating the counter has reset.
Dec 11, 2012 | Zenith D60WLCD Television
My sony trinitron won't come on
From your description it sounds like you TV is experiencing a shut down and re-set condition. This is usually caused by some type of voltage irregularity in the power supply section of the TV. Unfortunately, this is not an easy fix and will require a trip to the shop. Get an estimate before approving repair. In the new world of disposable electronics the cost of repair may exceed the value of the set. Keep in mind that TV components are most prone to failure during the electrical surge when you turn the TV on. So constantly pushing the on button will accelerate a permanent failure.
Aug 28, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
TV Does not Turn on
it sounds like the power transformer maybe out on the set.it supplies power to the whole set and it sounds like it only getting partial power.
Jan 17, 2009 | Panasonic PT-52LCX66 Projection Television
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
TV won't turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 25, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Picture and sound gone
your fuses may have blown off.
open the back panel and check all the fuses. There are a bunch of fuses in there, my tv has 5 altogether.
I hope this is the problem.
Feb 24, 2008 | Televison & Video
Mitsubishi WD62527 62 in. LCD HDTV Logo
373 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
