Question about Toro Garden
How do i replace a drive belt for the toro lx425 lawn tractor?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual......
Posted on May 20, 2014
2 Suggested Answers
  • 203 Answers
SOURCE: How do I get instructions on replacing both upper
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Posted on Oct 25, 2009
My Toro LX425 riding mower will not start has been fine all season; battery indicator light on but wont turn over; starter?
First make sure your battery is fully charged. The charger on lawn tractors will not keep the battery fully charged as they just produce a light charge. Check battery before the starter but if battery is fully charged then it's possible the starter could be bad.
Oct 15, 2016 | Toro Garden
What is wheel drive belt size for toro lx 426 lawn tractor
Motion drive consists of two belts,
Engine to variable speed pulley 5/8 x 90-1/2
Variable speed to transmission 5/8 x 42
May 30, 2015 | Toro Garden
Blades will not engage on toro LX426 Lawn Tractor
Either The drive belt for the blades has come off, or it has broken.
Jul 03, 2014 | Toro Lawn Mower With Toro Power Tools
How do I change the drive belt on a Toro LX466? Also, what would cause this lawn tractor to go thru one drive belt a year since 2008?
well I have a Lx 500 and the problem is that the bearings on the pulley shafts are wore out, makin the pulleys hard to turn or dragging heating up your belt. It heats up from the friction of the pulleys not free spinning like they should. next time you have the belt off check out the pulleys and see if they spin freely that will be the tale tell sign.
May 04, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Lx425 has grinding noise but won
replace the starter gear. the starter is probably fine and alot cheaper if you just relplace the gears.
Jul 14, 2010 | Toro Garden
How do I get instructions on replacing both upper and lower drive belts on a LX425 Toro Lawn Tractor?
Oct 25, 2009 | Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
1,540 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
