Question about Hunter 27185 Remote Control
I have a Hunter fan with remote and the light flickers without coming on completely - and you can hear a clicking noise coming from the fan. The fan works and the bulbs and batteries were changed
    Scholar:
  • 143 Answers
The pins inside the remote could have been switched or the wiring inside the fan could have come loose. Check the wiring at the fan first. The vibrations of the fan could have worked the light conrol wire loose.
Posted on Oct 10, 2010
How do I repair a Hunter Ceiling Fan thats blades won't spin?
The remote receiver could have failed partially so only light control works.
May 26, 2015 | Hunter Dryers
We need to replace the original remote unit from this fan (Model 9308R) since I wan to use LED bulb and it is not compatible....does not turn off completely and flickers when on. We purchased a universal...
Did you make sure the fan speed switch is set on high? Also, double check the remote wiring to make sure the fan wire is not disconnected. There's no such model # for hunter as 9308R!
Sep 24, 2013 | Hunter Dryers
52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Sep 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Flickering lights
make sure you have the remotes/receivers set to different jumpers. I installed 2 fans and had the same problem, just had to change the jumpers on one of the fans and the corresponding remote
Jul 19, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Hunter Fan - fan turns on and light goes off
you need to check the wiring and make sure factory dip switch settings are set
Jul 12, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Jun 20, 2009 | Hunter Ceiling Fan Remote Receiver...
Hunter ceiling fan model #23457
If it is tripping the breaker it has a serious load on it! You either have a dead short, like a wire being pinched by the cover, or pinched against the box or something like that, or a bad receiver. I really doubt that this is a receiver problem though. That would mean the load is all from the fan, and something would be smelling hot. If it tripps the breaker without the fan trying to come on, I would just about guarantee that a wire is being shorted to ground somewhere.
Nov 06, 2008 | Hunter 52" Ceiling Fan With Light And...
Hunter Fan
check your remote sensor inside the fan housing and make sure it's wired properly. Sounds like the solonoid is not wired correctly to the light. Hope this helps. Good luck.
Aug 25, 2008 | Hunter (25417) Ceiling Fan
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Televison & Video Logo
375 people viewed this question
Top Hunter Televison & Video Experts
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Henry  Thomas
Henry Thomas
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
