Question about Apple iPhone Smartphone
I get this pop up on iphone "This accessory is not optimized for this iphone. you may experience noise caused by cellular inference and a decrease in signal strength." option to dismiss, dismiss and it comes right back. still can use my phone in between the dismissing of pop up.but when i make a call the person on the other end cannot hear me but i can hear them.But when i switch to speaker phone they can or when i use headphones. Thanks any advise would be great regards Tristan
    Habit-Forming:
    New Friend:
  • 51 Answers
I would recommend plugging into iTunes and backing up your phone. After you back it up, restore the device. Set up as new and test it. If the issue is resolved you can restore from your back up. If the issue comes back then you will need to set up as new
Posted on Jun 02, 2017
3 Suggested Answers
  • 8 Answers
SOURCE: Getting a continous message that
This may be caused from liquid or physical damage to the iPhone, usually in the dock connector/receiver/headphone port.
If you're confident it's not caused by that, a quick fix would be to simply powercycle the device, an obvious step but overlooked a lot. Simply hold the button at the very top of the iPhone until you see Slide to Power Off appear on the iPhone display, do so and leave it off for atleast 30 seconds and do the same thign to turn it back on, until you see the Apple Logo appear.
If this doesnt work, another quick fix may be a software reset, you will not lose any data, through Settings > General > Reset > Reset All Settings. It will tell you that you are NOT going to lose any data and it will simply reset. This will turn the iPhone off and on, test it after this.
Last step, restore the device through itunes using a computer. -Plug your iPhone into your computer using your USB Cable that plugs into the charger. For best results, plug into the back of your computer as they can be higher power. -Open iTunes, make sure its fully updated, it will automatically ask you -Click on your iPhone on the left hand side of the iTunes, in the Column, beneath Devices -Click Restore on the main window of iTunes, half way down -Agree and Accept the Restore, this will erase all of your data -Backups are automatically created by iTunes, however they can store corrupted files and its best to not use them in this situation -For more information on Backing up your data via syncing and Restoring as New, follow this article: http://support.apple.com/kb/ht3828
Posted on Aug 21, 2011
SOURCE: When I plug my iphone
I have experienced the exact same problem, all of a sudden both my iphones stopped working with my Sony SRS-GU10iP. Error message Accessory Not optimized For iphone
Posted on Sep 10, 2011
Getting a continous message that "this accessory is not optimized on this iphone - you manyexperience noice caused by cellular interface and a decrease in cellular signal strength"
Aug 20, 2011 | Apple iPhone 3G
I have a pop up message that states, "This
if you've already restored it, you can take it to the store to have it replaced
Mar 29, 2011 | Apple iPhone 4 Black Smartphone
Keep gettin pop ups on my screen saying! this accessory is not optimised for this iphone you may experience difficulty noise etc as if its plugged into sumthing that doesnt support iphone~ loosing...
Sure, which ever accessory you are trying to use with your iPhone is not compatible. As Apple releases new products, many of their older accessories become not compatible with the new models. Sadly, you will most likely have to replace your old accessory so it works on this version of the iPhone.
Feb 28, 2011 | Apple iPhone 3G
This accessory is not optimized for this Iphone keeps popping up
You must be using an accessory that is not an official Apple accessory. Just dismiss the pop-up and continue using it if it functions properly.
Feb 21, 2011 | Apple iPhone 3GS Black (16 GB)
I have a message that keeps appearing on screen saying, "This accessory is not optimized for this iphone". It then goes on to say "you may experience noise caused by celular interference,...
If it is appearing when you connect to a 3rd party charger then that is expected. If it's happening randomly you need to restore the iPhone with iTunes. Should that not fix the problem then you will want to have the iPhone replaced if there is any warranty left on it.
Feb 17, 2011 | Apple iPhone 3G
This comes up on my iPhone ALL THE TIME and is interfering with my sounds. It thinks that it is still hooked into the stereo. It doesnt stop saying THIS message and it is getting annoying!!! Please...
Replace your dock connector board. If you have water damage, then clean your circuit board with isopropyl alcohol. Of course, you should talk to the genius bar first.
Dec 29, 2010 | Apple iPhone 3G
My iPhone WILL NOT stop repeating this message... It is interfering with my sounds because it believes that it is still plugged into the stereo!!! The error message reads...."This accessory is not...
you'll need to restore your iphone to factory settings -
Use the following steps to restore your device:
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new..."
When I plug my iphone 3gs in to my sony srs-gu10ip sound dock it says this accessory is not optimized for this iphone. You may experience noise cause by cellular interference and a decrease in cellular...
Dec 17, 2010 | Computers & Internet
Apple iPhone Smartphone Logo
295 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
