Question about Maytag Washing Machines
I have a Maytag performer series machine,the main agitator is screwed down properly but the corkscrew agitatorthat is attachedto the main agitator completely cuts loose and floats to the top , i don"t see how it is connected to the agitator at all.Please advise, if you can, thanks a bunch
With the Maytag Performa series, the auger is held by a pressure fit only - no screws. Mine failed after about 6 years. There is no (easy) way to repair this problem. The top auger does not stay attached to the post, and it floats off the post while washing... I ended up ordering a new one from the Sears 1-800 number. Easy to replace, and it comes with both the post and auger. Costs about $110, but certainly a lot cheaper than buying a new machine. The part does not come with the top cap for fabric softener, so be sure to save the old one. You do need a fairly long extension for your ratchet wrench to unscrew the attached bolt, but it is fairly easy to do.
Posted on Apr 17, 2009
Will not spin or agitate
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Nov 26, 2012 | Maytag Legacy Series Top Load Washer
Its a Maytag LAT9604 It has the 2 part agitator that Whirlpool developed. The bottom part does move back & forth but the top part only corkscrews if i push down or pull up on the top part. Evidently there...
That has a transmission in it very similar to a rear wheel drive car. They whole thing is very expensive and difficult to replace. 350 USD is the cost.
Nov 04, 2017 | Maytag Washing Machines
Maytag Frontloader (Perf series) brand new Agitator off axis
Okay! We just fixed this problem on our washer. First, be safe and be sure that the electrical cord is unplugged. Then you want to take the lid panel off of your washer. Then you'll feel around under the base of the agitator/washer basket. You should notice that its feet sit inside huge springs which are fixed to the base of the machine unit. Determine whether any of your basket feet are disloged from their spring and re-insert. Make sure the fit is good or else you might have the same problem again. After you reassemble, plug in the machine and try a test spin without any clothes. Then try with a smallish load.
Hopefully this helps.
Jan 04, 2009 | Maytag Neptune MAH6700A Front Load Washer
How do you remove the agitator if something is caught underneath.
On a Maytag the agitator either has a bolt under the center cap, or a set screw along the side about 3/4 of the way down. Maytag Alantis and Performa models have a removable agitator cap with a bolt underneath, while the Dependable Care series have a set screw. In either case, you loosen the nut or screw, and the entire assembly will lift straight up. Sometimes they stick and require a little effort to remove. I hope this helps you.
Sep 04, 2008 | Maytag Washing Machines
Seal leaking from tub. How do I remove agitator?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
Aug 11, 2008 | Maytag Washing Machines
How do you remove the agitator on a Maytag Dependable Care Washer?
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Aug 09, 2008 | Maytag Dependable Clean Top Load Washer,...
I have a foul smell comming from my washer I want to try to take off the agitator and clean it How? :)
It depends on what model Maytag washer you have. If you have an Atlantis or Performa model Maytag you remove the agitator by, first, pulling the agitator cap and softener dispenser off. Locate the bolt on the center post and and loosen. The agitator will pull straight up to remove. If this is a Dependable Care model Maytag, there's a 1/4 inch screw located on the SIDE of the agitator about 3 quarters of the way down. Locate this screw and loosen. The agitator will pull straight up to remove. I hope this helps you.
Aug 01, 2008 | Maytag Washing Machines
I have a 5year Maytag washer,the agitator completely lifts out of the washer machine
POP YOUR AGITATOR CAP OFF AND SEE IF ANY THING BROKE OR IF THE MAIN SCREW HAS COME LOOSE,THANKS-MIKE
May 29, 2008 | Maytag Washing Machines
How to replace gears myself?
Just went through an agitator problem with my MAV7700AWW Atlantis. You are talking about the main (bottom) agitator, not the corkscrew part up top, right? If so, you can check this site to see how to access parts inside your washer. I found it very helpful: http://www.geocities.com/maytagrepairwasher/
I too, had visions of replacing stripped gears, but after searching the internet for a few days, decided to buy a new transmission, replace it, and then tear in to my old one and repair it and then have the original for a spare.
I found a NEW transmission and tub seal kit for under $120 including shipping to my door.
If you have an Atlantis, then the following information will be very helpful. Otherwise, you may find that you have a transmission that can be serviced more easily.
When I finally got the old transmission out I was very happy with my decision. I cannot see how it comes apart - no screws, bolts, clips, or clamps. It is an upper and lower half that appears to be gooped together by a blue sealant. The new transmission appears to have the halves crimped together - maybe it is a serviceable part, but it is not very user friendly.
If you decide to tackle the job, I can offer a few tips on alternative tools and also on disassembly of the brake.
Mar 09, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Nov 28, 2007 | Washing Machines
Washing Machines Logo
242 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
