Why wont my motherboard display on a monitor at first I thought my video card was broken but after inserting a new one Im receiving the same results
  • Computers & ... Master
  • 5,660 Answers
A bad Power Supply with a weak voltage rail will produce this result also. Enough power to light LED lights, and maybe spins fans, but not enough to turn the Processor on.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is.
(Older Processors such as a Pentium II, or III for example, uses less Wattage)
No Processor operating, No computer.
No computer operating, No video signal.
Posted on Oct 10, 2010
  • joecoolvette
    joecoolvette Oct 10, 2010
    Sorry, I was supposed to be No. 3 in the que
  • 428 Answers
Change your RAM, and if no result it means your vga chip on the board is bad. To comfirm, check if your processor is warn when turned on. you may disconnect the processor fan to check this.
    Master:
    Sergeant:
  • 383 Answers
Is there onboard video, that you can try just make sure the its not the mother board
Compaq sr5010nx
>Delete the old Nvidia card drivers off your computer.
>Install the ATI video card drivers (you probably did this, but....)
>You may have to disable the integrated video on the motherboard (if you have it) in the BIOS setup screen.
>Make sure the new card is seated properly, take it out and reinstall it. This is one of the most common problems.
>Make sure the VGA or DVI pins in the monitor video cable are not bent or damaged. Another very common problem.
>Swap monitor with a different one; if you get video your monitor is bad or there are some settings need changing.
>Take the video card back, it may be bad.
Apr 11, 2014 | Computers & Internet
Problems booting
It could be either the monitor cable, monitor or motherboard that doesn't work. It could also be that you are running a BIOS version too old to support your new parts. I would try to update the BIOS and then troubeshoot a little to find out if, and which, part is broken.
Jun 11, 2009 | ASUS P5N-E SLI Motherboard
Black monitor no power
Hi. On some motherboards the 'Enable usb Support' option in system can cause this. Use a conventional ps2 mouse and keyboard, unplug all usb devices, enter system and ensure that 'Enable USB Keyboard Support' is turned off and continue setting up as usual. Try locating a bios upgrade for the mobo concerned.
I hope this helps. Let me know how you get on.
Apr 25, 2009 | Computers & Internet
Monitor working properly but it sounds continously,very noisy
hi im josh in cebu phils.may i help you? Friend try this solutions:
Problem: Your Monitor Doesn't Display—The System Unit Issues a Series of Beeps Your PC uses beeps to communicate with you when something is wrong with the video setup. Check the settings on your video card to make sure that they're correct for your system. Also check any switches on the motherboard to make sure that they're set up correctly for your type of video card. (You should consult your system's instruction manual for details on this procedure.) Check to make sure that your video card is seated properly in its slot; you may even want to try inserting the card in another slot. If none of these suggestions works, try a new video card, or have your system examined by a professional.
In a pre-Windows 98, system, if you have two video cards installed at the same time, they can sometimes interfere with each other and cause neither to work properly. Try removing one of the cards; if this results in the remaining card working, you need to reconfigure one or both of the cards to better work together. (With Windows 98 and later you can install two video cards to run multiple monitors simultaneously.)
Problem: Your CRT Monitor Doesn't Display—It Makes a High-Pitched Whine This whine indicates that your CRT-type monitor, for some reason, is operating at the wrong frequency. Turn it off immediately—this problem could seriously damage your monitor! Now check the settings on your video card. Chances are that it's set to a higher resolution than your monitor is capable of displaying. If this isn't the problem, your video card itself could be defective. If your video card is okay, your monitor might be defective.
Problem: Your CRT Monitor Pops and Crackles and Starts to Smell Like the rest of a computer system, monitors can get dusty. When dust builds up inside the monitor, it can generate static charges.
It's also possible that the power supply inside the monitor has become defective. If the monitor demonstrates these symptoms, turn it off immediately and take it to a repair center. The technicians can either clean your monitor or replace the power supply if necessary
You may visit your monitor services center if the problems stills occur after performing the solutions mentioned. hope i helped you friend good luck
Mar 10, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
Intel d845,one long 2 short beeps video problems
hi im josh in cebu phils.may i help you? friend try to use this solutions of mine surely it will help you.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician. Just try friend it will help you Good luck.
Mar 05, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Hi i have a intel D845 PESV motherboard
hi im josh in cebu phils.may i help you? Friend try to read these.ths may help you.
Remember these points when you have a video-related problem:
  • Most display problems are caused by video card/monitor mismatches, bad or outdated display drivers, or improperly connected cables.
  • One good way to determine whether a video problem is card-related or monitor related is to connect a different monitor to your system. If the new monitor works fine, the problem is in your old monitor; if it doesn't, the problem is with your video card.
  • Most video card–related problems will manifest themselves before Windows launches.
  • Most driver-related problems will manifest themselves after Windows launches. good luck.
Mar 04, 2009 | Intel D845PESV Motherboard
Monitor light will not turn green from yellow
hi im josh in cebu phils.friend if your pc wont display after the installation. the problem is centered on your video hardware. try to install the driver of your video hardware.or go to the bios setup menu then system performance down agp aperture increase the number if your using agp video cards it will help you. good luck
Feb 23, 2009 | Computers & Internet
Conflict with the display and the PC display will not come out
I think there is no effect even if the monitor was interchange, maybe during the travel the video card was loosen, have it check. Check also the pins of the monitor cable, if some are broken.
Thanks
Nov 21, 2008 | Asrock 775VM800 Motherboard
No display on monitor but cpu is running
The main problem is in the RAM or MEMORY CARD, just detach it and place it back or on another slot beside it.... if this dont work, buy a new memory card. but this usually works
Oct 26, 2008 | Asrock P4I45GV R5 Motherboard
After many faults my monitor is not receiving signal from my computer
Unplug your VGA cable and Switch on the monitor. It Should display a message that Cable is not plugged in like. If that message comes then monitor is alright. Once again plug and check the VGA cable of your monitor. If it works than its ok. Otherwise there is a problem in your display card which is present in the motherboard. You can insert an new display card or graphic card into your motherboard. Thank you.
Sep 09, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
