Question about Denon DP200USB TURNTABLE W USB Turntables Turntable with USB
Adjust weight on tone arm for denon dp 200 - Denon DP200USB TURNTABLE W USB Turntables Turntable with USB
3 Suggested Answers
  • 120 Answers
SOURCE: Denon dp-35F turntable.
It apears the lead wiring contact arrangement is typically generic. Green over Red and Blue over white. I searched Google by images and found the wiring arrangement in a detailed photograph of a Denon headpiece with cartridge installed.
So always remember to draw a diagram before disassembling something.
Posted on Apr 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: How do you adjust the
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Posted on Apr 14, 2011
Denon dp-26F when i tried to play a record the arm just skated all the way across the record. is there a way to adjust the arm so it plays correctly?
The short answer is that you need a new stylus as the one you have is either broken or worn away so that it won't stay in the groove. It could also be out of place. Rubbing your finger on the stylus you should be able to feel it digging in. If you can't it's gone!
Nov 16, 2014 | Denon DP-26F Turntable
Denon DP-7F subweights
I don't know what you are referring to as sub weights. Everything you need is already on the tonearm.First you have to balance the tonearm, then you adjust for stylus pressure and anti-skating. For more information, please my website at audioserviceclinic.com. Thank you.
Nov 23, 2013 | Denon DP-47F Turntable
In my DENON DP-300F tone arm don't come back after playing record. It just stays in the end of record? How can i fix it?
A lot of decks don't actually do that anyway. But if it previously did this then it's probably a mechanical problem. Removing the bottom of the turntable might show up the cause of the problem.
Dec 08, 2012 | Denon DP-300F Turntable
Denon DP-297 Turntable Tone Arm Skating
There should be a weight on the end of the arm, this needs to be adjusted. Some have numbers on them, increase the number shown. To get it to work right you will have to do it by trial and error. Increasing the weight in small steps, then playing a record. The trick being so it stays in the groove, but not too much so it rumbles on the sound. You will need to repeat the process several times till it sounds right and stays in the groove.
Jan 10, 2012 | Denon DP-29F Turntable
When I push start the arm does not lift up but does move over to record,then never drops to record.I just replaced original cartridge (DL-160) with same N.O.S. one after 14 years of no use I followed the...
the cartridge may be a different weight,, you have to adjust the rear weight to compensate for the difference ,, make sure the drop armm isn't on the up setting,, Ive done that and Ugggg felt really dumb
Jun 12, 2011 | Audio Players & Recorders
Denon dp-35F turntable. What is the tone arm lead wiring layout? The cartridge is labeled RWGB, but not the tone arm.
Apr 10, 2009 | Denon Audio Players & Recorders
Skatinig
You need to adjust the downward force by adjusting the counter weight which is on the back of the tone arm. Rotate it so it's closer to the tone arm fulcrum to increase the weight on the arm, like tightening a nut on a bolt.
Oct 04, 2008 | Numark TT1520 Turntable
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Re:
Hi Vat,
Although I live in Canada now, I was born in the former
Czecholsovakia. While I spent a year in the Czech Republic in
2006, I was amazed how advanced their technology was, in
comparison to Canada or the US. If you want modern technology,
Prague is the place to go. Anyway ...
1) As I said before, do NOT adjust the tone-arm weight up
and down. This setting must be set to match the stylus and
the cartridge !!! The wrong setting is very bad.
To get the weight adjusted correctly, do the following.
a) Check the cartridge and stylus (needle) specifications, on
the WEB if necessary.
A typical tracking weight is between 0.9 grams to 1.5 grams,
but this very much depends on the needle geometry. To much
weight will damage the needle and the record, but
so will too little, because the needle will not stay on the
surface, skipping or mistracking on loud passages.
Note that the tracking acceleration is proportional to the
the square root of the loudness, multiplied by the frequency
squared. So if the tracking force is too low, the needle will
bounce over high frequencies and damage the record as
well as the needle's tip.
2) Once you know the correct force for your needle, adjust
the rear weight for ZERO force, such that the needle just
floats weightlessly in the air. If your turn-table has an anti-
skating adjustment, set that to zero as well.
3) At this point the tone-arm should be totally weightless,
and should neither touch the plater nor swing up/down
by itself. It should float halfway.
4) A this point, adjust the rear weight's dial (not the weight) to
read zero. Note that the dial will slide, while you hold the
weight still. You have now calibrated the tone-arm's zero
point.
5) Now, adjust the weight (with the dial) to read the desired
tracking force, for example 1.25 grams.
6) Now adjust the anti-skating dial to the same number as
the rear weight. This setting compensates for the radial
(towards the center) component of the friction vector,
caused by the needle riding on the record groove, at some
specific (average) tone-arm angle.
7) Your tone arm is now balanced, and you should not
touch it after this, accept for minor adjustments.
For brand new records, you may lighten the tone-arm
by 10%. For old records, you can make it a little heavier.
Similarly, you can adjust the anti-skating to prevent a
record from skipping, but a bad record should be played
only once (and stored on your computer).
8) For some tone-arms and cartridges, the cartridge pitch
(up/down angle) is also adjustable. This requires a special
jig or gauge, supplied by the cartridge manufacturer.
The pitch can be adjusted either by the use of screws or
wedges, and by lowering / raising the rear gimble. On my
Technics SL 1200, the gimble elevation is adjustable with
a large ring, and my SURE V15 cartridge came with a guage
for adjusting it correctly.
9) It may also be possible to adjust the cartridge's yaw and
radius, but all of these adjustments should only be done
using the correct gauges and by strictly following the
cartridge installation manual.
10) NONE of these adjustments should effect the tone-arm
cueing or return process. There should be plenty of
clearence if the cueing mechanism is working properly,
except, perhaps, for the gimble elevation, if the cartridge
is unusually tall.
11) Is the cuing mechanism (i.e. the tone-arm lifter)
mechanical or hydraulic ?
Is it the lift consistent or does the tone-arm drop down
with time?
Does the tone-arm move parallel to the plater, or does the
stylus height change with tone-arm position (yaw)
You are looking for a mechanical defect in the cuing
mechanism.
12) How much over all lift do you get between the down position
and the up position? This should be at least 8 to 15mm
If the cuing mechanism is worn out, it may not move enough.
If it starts too low, it may move enough but not raise the
needle enough to clear the record.
If the cartridge is tracking too low, you may have to
remove some wedges or spacers between the cartridge
and the head, or lift the rear gimble if it is adjustable, or
get a different tone-arm head, that matches the cartridge
profile.
Finally as silly as this sounds, make sure that the
platter is fully dropped and properly engaged. If the
plater is too high, for what ever reason, this would also
cause the needle to drag.
Also make sure that the rubber mat on the plater is the
right one and that it is not too thick.
Martin
Jul 02, 2008 | Audio Players & Recorders
Denon DP200USB TURNTABLE W USB Turntables Turntable with USB Logo
120 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
