SOURCE: Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
SOURCE: Monitor goes black and both blue lamp blinks
have a tech check your tv there is a fault in tv horizontal circuit.good luck my friend.
SOURCE: Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
SOURCE: Insignia NS-32LCD will not turn on.
I bought a 32' LCD TV made from insignia and it will not turn on. It was a 'open box item' now it is 15 months old- 3 months past warranty and it is completely finished. It's something to remember about Best Buy products. They are often pieces of junk. Isignia and Best Buy both have unavailable customer support, the local store transferred me from sales to Geek Squad- after Geek Squad said they don't do TV's I was transferred to a line I let ring for 2 minutes and the phone was never answered. I have been going to Best Buy instead of Circuit City but this has concerned me enough to not spend money at Best Buy anymore.
SOURCE: samsung tv turning off by itself
I have the same problem of the set turning off and on by itself. There is a circuit in Samsung TVs that would shut it down if a very loud noise occurs in the program being watched, but I have not noticed that correlation. My problem is solved by vacuuming the back panels of the set. They do not seem to have any significant dust on them, but I think the vacuum sucks somewhat inside of the TV and does some good with the fan that is supposed to be cooling the bulb and the mirror. It seems to work for months on end and when the problem recurrs, I vacuum again.
