Question about Belkin Computers & Internet
CONNECTION PROBLEMS WITH BELKIN N1 ROUTER /MODEM
  • Ruben Deb May 11, 2010
    What exactly happens when you try to connect. Does it give you any error messages? And how are you trying to setup the connection.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    ahh..well..do you have the user installation guide?
    Sergeant:
  • 458 Answers
YOU CAN RESET THE ROUTER TO FACTORY SPECS IF YOU INSERT A PIN INTO THE TINY HOLE IN THE BACK. THEN YOU WILL NEED TO LOOK UP THE MANUAL TO TELL YOU HOW TO SET IT UP. Sorry about the caps. The button stuck.
Are you trying to go wireless? Wireless settings will need to be passworded as per the manual. Your computer will have to have wireless connection and it will need to be set up correct also. Default settings usually work. The drivers will allow you to set up the wireless card in the computer. Go to the web site and find the drivers and the manual. This can not be done by one of us here. We can help after you have done everything that I told you to do but it will work if you follow my directions.
Posted on May 30, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Can you please let me know if this solved your problem?
    Rate this as a fixya if your problem is solved please.
    If you need more help let me know.
2 days ago my router seem to lose connection and says theres no modem or internet connection.. and modem is perfectly fine. After i unplug and replug the power, it works for another 5to 20 mins then have...
This is because your router is dropping the connection with your ISP Modem...
It can be even an issue of modem...
To isolate the issue, what you can do is... You can connect your computer directly to the Modem and you can check for any intermittant connectivity...
if you dont have any problem with your modem, then definitely its gonna be the problem with your Belkin Router...
Doing a reset for the router and reconfiguring will resolve the issue in most of the cases...
If in case if it doesnt works, then you can do a firmware update for the router (that would be found in belkin router support website)...
Even then if it is dropping the connection then definitely it is a faulty router...You can ask for a replacement if the product is still under hardware & software warranty...
i work for belkin...
you can reach us any time in 1800-223-5546 if u are calling from USA...
we work 24 X 7....
For any other countries search in www.belkin.com/support
Dec 09, 2010 | Belkin N1 Vision Router
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
Regards,
Aysaam
Apr 13, 2010 | Belkin N1 Vision Router
My Belkin N1 router can't seem to establish connection with the cable modem - the router light flashes and connects but as the internet light flashes it loses the router light again. It is still allowing...
the modem is working fine. the connection might be dropping from the router side.
You can try to upgrade the Firmware of the router.
reduce the MTU on the router. If it is on 1500 the reduce it to 1400.
Click Here from more info about routers
Oct 31, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin 8231-4 N1 router lost connection to cable modem
It sounds like a problem with the cable provider or cable modem. I have found the local equipment can develope a problem and most customers in that small area think it is their problem and live with it. If you have not called the cable company then get them on the case. Good luck
Sep 13, 2009 | Belkin (F5D8231-4) Wireless Router...
I have lost connection between router and modem (no modem light)
make new connection or check the device is enabled or not in the properties....
Jul 16, 2009 | Belkin N1 Vision Router
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Email problems with Belkin N1 wireless router
Disable your Firewall/NAT service or open ports 25, 110 and 141
Dec 12, 2008 | Belkin (F5D8231-4) Wireless Router...
Major issues
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now.
Hope this helps, and good luck!
Apr 16, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Nov 09, 2007 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
53 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
