Question about Bosch Nexxt WTMC3321US Electric Dryer
Our start button on our bosch nexxt electric dryer doesn't click and the dryer will not start.
    Scholar:
  • 39 Answers
Not sure if this will address the problem but it maybe worth a try. We also had problems with our Nexxt dryer starting. We found the problem was with the start/stop button; it was not making contact with the mini-switch. Used some hot glue under the lever that makes contact with the mini-switch. Put it back together and works great again. Saved about $260 on new control panel. Removing the control panel was pretty easy for a DIYer.
Unplug the dryer.
Remove the four screws that hold the panel in place. They will be hidden under caps on the housing, Pull off the panel. Be careful because the wires will prevent you from pulling it entirely off but you can pull it from the right corner up and flip it on its back side to expose the back of the panel.
The white wire guard will have to be removed. The wire ties holding the wires to the guard will have to be removed by cutting the ties. Replacement wires ties can be purchased at any home improvement store. Remove the control panel by pushing the plastic clips in that hold it to the housing. There should be 6 and two plastic clips on the right center of the panel. If done right it will easily pull off. If force is needed one or more of the clips have not been disengaged. Do not force it because it is made of plastic and will break.
Once the control panel is removed from its housing, the start/stop button can be identified-last one either on the right or left (can
Posted on Dec 04, 2010
  • Jason Wiggers
    Jason Wiggers Nov 07, 2015
    is there a way to read the entire thread?
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
Jun 05, 2012 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch nexxt 800 series wtmc8520uc not working
How do you get to the motor mount? Where is it located?
Jan 22, 2012 | Bosch Nexxt WTMC8320US Electric Dryer
I have a Bosch WTMC3321 electric dryer, all of a sudden it does not work. You hit the start button and it clicks but the dryer does not spin.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Bosch Nexxt WTMC3321US Electric Dryer
Bosch dryer has pwr but not turning on
Sounds like the belt is broken or off of track.
Jun 03, 2009 | Bosch Nexxt 500 Plus Dryer
Bosch Nexxt Electric dryer tumbling but not heating up at all, I here rumors of a reset switch. Where is it located?
Unplug the dryer first. Then remove the back cover on the dryer. You will find the red reset button underneath the dryer drum. If the button has been tripped, you will feel and hear it click when you press it in. I would suggest that you vacuum out any dust or lint that has collected inside the unit before replacing the cover.
Feb 28, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
My Bosch nexxt electric dryer won't turn on
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Nov 04, 2008 | Bosch Nexxt WTMC3321US Electric Dryer
Bosch Nexxt WTMC3321US Electric Dryer Logo
789 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
