Question about Olympus FE-340 Digital Camera
When power my fe 340, red light blinks but lens stays in and power goes out.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Blinking red light indicates that the battery is unable to charge, to start with you can take a Q-tip dipped in alcohol and try to clean the battery & charge contact points and then try to charge the battery again. If the issue is still not resolved then the battery should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 10, 2010
I have a Olympus FE-340 that when I put the power on the lens goes in and out and then shuts off .
This sounds like a very low battery. If it won't charge up, then the battery may simply have come to the end of its useful life and need to be replaced.
Oct 16, 2010 | Olympus FE-340 Digital Camera
The cameral lens, on my Olympus FE-340 goes in and out and then turns off when i'm trying to turn it on. ONLY 2 years old!!!
i hv the same problem the lens goes in and out...my frens gurl has one n its the same problem....its a nice camera but it worthless
May 07, 2010 | Olympus FE-340 Digital Camera
On last pwr down the lens only retracted halfway. Now, press pwr button and the pwr lite blinks 3X, stays lit, blinks 3X, goes out and the camera does nothing. Is it brain dead? Tnx, Bobert
Try replacing or charging your batteries, then see if that fixes it. Lens could be stuck by dirt or something, see if you can gently assist it closing when you power it on again. Other possibility that comes to mind, other than being "brain dead", is that the gears that drive the lens have broken or jammed. Not sure what a camera shop would charge to check it out, but you might try to get a good used one on Ebay, they seem to go for around $60. Hope this helps!
Feb 25, 2010 | Olympus FE-340 Digital Camera
When I press the power button, the screen stays black and the lens goes in and out and then it dies. Why is this happening and how can I fix it?
First sounds like poor battery, but you've checked that of course. Other cause might be dirt between the lense's retracting parts which prevents the lense to fully extend.
Sep 25, 2009 | Olympus FE-340 Digital Camera
Olympus FE-340 camera i turn on the power the lens goes in and out 2 or 3 times and the view is blurry in the view finder. The zoom feature has no effect when pushed to the wide setting and will turn off...
your lens may be damaged...your zoom assignments may need to be realligned if there are no broken parts. If there are broken parts in your lens it may be better to get a new lens
Aug 10, 2009 | Olympus FE-340 Digital Camera
Olympia fe-340 won't fully turn on
You have a bad lens, you should take into a camera repair shop. The only other thing that can be possible is the cable from the lens to the camera man board may have not be making proper contact.
Jul 02, 2009 | Olympus FE-340 Digital Camera
Fe-340 wont turn on
If the lens is stuck out, that either means impact or it got squished and messed up the lens mechanism. You can have that repaired.
Apr 20, 2009 | Olympus FE-340 Digital Camera
Olympus fe-340 doesnt stay on
go get duracell rechargeble the green one digital camera need powerfull battery let me khow
Dec 29, 2008 | Olympus FE-230 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
Olympus FE-340 Digital Camera Logo
130 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
