Question about Brother MFC-7820N Laser Printer
My Brother MFC-7820N has a paper jam problem that seems to be related to it's picking up an additional sheet of paper and when the first sheet completes it's print pass, the second is midway and the printer shows an error. I only have this when I have more than one sheet in the paper tray.
  • gmurugesh Oct 10, 2010
    Thank you for the suggestion.
    The problem is to do with the fact that the printer is picking a second sheet even if only a single sheet is to be printed. Seems to be a setting or a sensor issue.
  • 50 Answers
Most paper has a smooth side and a little less smooth side, try flipping the paper. in the pack use the top side as the printing side when u load. try a different brand of paper could easily correct the problem,
some feed trays work best when nearly full also, try half full etc.
Posted on Oct 10, 2010
Paper jams when I put it in the tray to fax (from the top tray)
your wheel on one side is impacted with small pieces of paper
this causes the paper flow to go unevenly you need to clean you wheels on both sides oil them and wipe dry with a paper towel
then do the paper feed jam clear and let a few pieces go thru to pick up any remiaining debris
Aug 22, 2012 | Brother MFC-7820N Printer
Our Brother 7820N all of a sudden started paper jamming. Took everything out and it still jams. What can I do.
Try the link below, if its not working that may be a hardware issue and needs repair: 7820n Paper Jam
Aug 26, 2010 | Brother MFC-7820N Laser Printer
Paper feed jams. feeds from lower tray, turns 180 deg. then jams. Single sheet feed is fine
while keeping the paper .. ensure that it is properly stacked... fan the paper and ensure that it is not stuck to each other.. also open the printer cover and see if any paper is stuck inside..
Try to open the rear access door ,and clean the paper roller with slightly damp lint free cloth
Aug 12, 2010 | Brother MFC-7820N Printer
My Brother MFC-7820N has trouble picking up sheets of paper
Hi! I just recently noticed that the 7820N has an "extension" piece at the back of the paper tray. This extension should be pulled all the way out and the blue paper stop adjusted accordingly. Otherwise, the loose extension piece will slide out from the rear of the printer when the tray is slammed in, and the paper will not be where the the printer expects it to be.
Other than that, check that the pad at the front of the tray is clean, and that the plastic small roller next to it rotates freely. Also, try cleaning the rubber rollers that are located inside the printer above the tray with a damp cloth.
Apr 02, 2010 | Brother MFC 7420 All-In-One Laser Printer
Frequent Paper Jams in Brother HL-2140
Every 120,000 pages, the paper feed rollers, fuser, transfer roller, and OPC belt cartridge should be replaced, usually by a trained techncian.
Fuser and OPC belt units are customer-replacable.
The multiple feeding of the paper into the printer is due to a worn paper separation pad. part no. LM0711001. If the machine is picking up the paper okay and the jams occur solely from multiple sheet feeding, then this part is probably all you will need. The steps required to access and remove & replace the separation pad unfortunately is about 10 steps. Better consult a tech.
Oct 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Recieve multiple paper jams that wont stop!
Is there a sensor flag that is stuck and/or broken?
May 22, 2009 | Brother MFC 7420 All-In-One Laser Printer
Continual paper jams in rear of printer
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
Jan 03, 2009 | Brother MFC-7820N Printer
Back cover open message on brother mfc 7820n
Had same problem. Closer inspection revealed bit of paper out of sight. Removed the toner cartridge and worked to free torn paper. Then restart. Hope it helps.
Dec 15, 2008 | Brother MFC-7820N Printer
ADF (automatic document feeder) constantly jams
change paper pick-up roller & paper stop roller in ADF
Oct 30, 2008 | Brother MFC-8840D All-In-One Laser Printer
http://www.fixya.com/support/t150137-one_more_person_back_cover_open_problem
Oct 24, 2008 | Brother MFC-7820N Printer
Brother MFC-7820N Laser Printer Logo
861 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
