Question about KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher
Maytag dishwasher model MDB9150AWB -on the 'rinse only' cycle the water pumps out fine but on the 'normal wash' after 20 minutes of washing the pump won't start. I can hear a slight beeb or ping as pump trys to start, repeats every 5 seconds.
  • KitchenAid Master
  • 3,247 Answers
I believe your model of dishwasher requires hot water inlet connection. Have you checked the inlet water temperature is within the recommended range per the user manual?
Posted on Oct 10, 2010
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Dishwasher Stuck Mid Cycle
Jiggle the water level float sensor .It is stuck .
May 14, 2012 | Maytag Dishwashers
Dishwasher detergent does not dissolve during cycle. Clumps in prewash and main wash compartments
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Feb 20, 2010 | Maytag MDB5100A Dishwasher
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Kenmore dishwasher various problems
The portable dishwashers of the 70's and 80's often had one area of problem, and that was the pump getting jammed with debris and food.
To eleminate this problem, you will need to open up your dishwasher carefully, and drain all the water and gunk from your dishwashers rinse hose. I recommend taking the machine outside and use a low setting pressure hose (garden hose). With the hose off the rinse side, run the water through and see if it comes out of the pump's housing. Let it run for a few minutes.
The pump also has a switch that also goes with the run cycle. This switch thinks there is not enough water or it thinks it has done its job.
Sometimes replacing the timer helps, but first eliminate the lower hose situation first. If that doesn't help, you will need to then replace timer. If this doesn't help, most likely your pump is most likely jammed or malfunctioning.
May 24, 2008 | Dishwashers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher Logo
137 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
