Question about AEG Lavamat 72640 Front Load Washer
Aeg washing machine
Ive just got this aeg 72640 update aeg washing machine but no instruction and i wondered if i could get some over the internet
  • forest red Jun 03, 2008
    worked just the trick thank you
  • Anonymous Mar 14, 2014
    aeg washing machine not spin
    President:
  • 1,294 Answers
Click on 'washing machines' (below FIXYA) on this website, & search witrh your model number. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is..
Posted on May 30, 2008
I have a aeg 72360 update washing machine and it keeps stopping and coming up E20. It will not spin
make sure the drain pump is operating correctly or if so, check the motor brushes.
Aug 09, 2010 | AEG Lavamat 72640 Front Load Washer
Aeg oko lavamat 72600 update, ce error code showing any idea?
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG WASHING MACHINE
fit hoses at random. put on a rinse cycle. if cold water comes in then hoses are correct. if hot water comes in, then reverse hoses
Aug 22, 2008 | AEG Lavamat 72640 Front Load Washer
AEG oko-lavamat 72630 update
It is a communication problem between the circuit boards inside the machine. It might be as simple as unplugging and replacing the wires, or you may indeed require a new circuit board.
Aug 05, 2008 | AEG Lavamat 72640 Front Load Washer
AEG 72640 update
e20 means cant drain i usually found itsufficient to clean filter and restart but this time i blew down waste pipe /drain,cancelled program and reset
Jan 13, 2008 | AEG Lavamat 72640 Front Load Washer
AEG 72640 Washing machine
Try:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | AEG Lavamat W1450 Front Load Washer
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
May 18, 2007 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 72640 Front Load Washer Logo
492 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
