Question about Denon AVR-5805 Receiver
Were does the center speaker connect - Denon AVR-5805 Receiver
Second row down.. not sure if it left or right side.. but one is a blank.. so don't use it for anything.. My guess is if your looking from the front of the unit it is the one on the left.. my 5805 just lost sound.. sucks...
Posted on Jun 18, 2011
My center speaker connection is faulty?
There should be some fault to internal output circuit.
May 11, 2013 | Philips Audio Players & Recorders
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
What's the proper way to wire 2 sets of speakers,
the center speaker is easy just wire it to the center main posts (connections are near the middle of the box) (just match up the colours)
and the powered speakers do they have their own amplifier or are they just speakers
if they have their own amplifiers then use the pre out connections near the top of the box
if they are just speakers then
wire them to the front main speaker connections near the right of the box
May 10, 2010 | Denon AVR-1700 Receiver
Center speaker no longer works
Wiggle the connection that the center one is plugged to. It starts static or playing then the internal connection is broke loose from the solder joint.
Plug another speaker to that connection. If it plays then the speaker is blown.
Feb 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Center channel sound output
Its not working correctly I have a few different types of center channels and they all have equal sound no matter how many speakers are in them. Connection in speaker box is bad or you may have a blown speaker
Dec 31, 2008 | Pioneer VSX-455 Receiver
Missing center speaker
Yes, you can connect all the other speakers and not have a center speaker. It will not damage the amplifier. But be aware, that many of the surround functions will not sound good without the center speaker. In just about every surround mode the center speaker gets more audio to it than any other speaker. It would sound better if you took one of the rear speakers and used it for a center speaker and have one rear speaker output no connected. The rear speakers get the least amount of sound going to them in all surround modes.
I hope this helps and a Fixya! rating would be appreciated. After all, it is the only reward we get for offering people like yourself free help. Most people never even bother to rate our free help here.
Thanks,
Dave
Nov 02, 2008 | JVC TH-M606 System
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
Center speaker will not work
If you had the Speakers Set to A (not B) and no headphones connected when you pressed the TEST TONE button on the Onkyo HT-R540 (also known as the HTS-790) remote, and you had no sound from the Center Speaker then try the following steps. 1) Check the Center Speaker wiring at both ends under a bright light and make sure that there is not a strand of wire touching the Receiver Chassis or another speaker post. Check both + and - . If that looks okay, 2) unscrew the Center Speaker Post connections on the Receiver and verify that the bare stripped wire is making contact. Often, the insulation is too far into the connector. When screwed down, the wire's insulation is crushed and keeps the bare wire from making contact. If this looks okay and the unit is under Warranty, your last test is to: 3) temporarily swap the wires from the Center Speaker with the Right Front Speaker. Turn the volume down low and try the TEST TONE button again. If you now hear sound from the Center Speaker box itself and none from the Right Speaker box, then the Receiver is the problem. If you still do not hear sound from the Center Speaker box, then the Center speaker itself is defective.
Sep 25, 2007 | Televison & Video
Denon AVR-5805 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
