Question about GE Nautilus 24" Built-in Dishwasher
The dishwasher won't fill with water enough to cover the heating element.
    Problem Solver:
  • 11 Answers
Make sure the drain hose is at least as high as the top of the machine
Posted on Oct 10, 2010
Can I use cold water fill when installing this machine
No,
There are only a few dishwashers that have good enough heating elements to be able to use cold water.... most all of them need to fill with hot water and then the element just keeps the water hot...
heatman101
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Oct 10, 2010 | Dishwashers
Dishwasher not getting enough water in either drawer, although top drawer gets more. Dishwasher keeps beeping during cycle and reads not enough water and then stops running until you press the start...
This sounds like a hard water deposit problem.
Check your water inlet valve for a screen and see if its clogged. Also it may just be a water valve/solenoid problem. As in, it's too crusted up to float up and down.
Some models have a water fill timer, while others use a water fill/pressure switch. This may also bear inspection.
The beep you hear during your cycle is indicating that your water level is too low to cover the heating element, which can cause cracking and lead to a short.
Mar 07, 2010 | Fisher and Paykel DD605FD Stainless Steel...
Dishes in top rack don't clean
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 05, 2009 | Whirlpool 24 in. GU1200XT Built-in...
HM603222A moffat dishwasher...not cleaning dishes. Food particles are being circulated around and drying on dishes
Hi
Thanks
Rylee
Aug 29, 2009 | Dishwashers
Dishes are dirtier when they come out than when I put them in. Covered with grainy substance. Help?
Hi
Thanks
Rylee
Aug 20, 2009 | Gibson Dishwashers
Kenmore dishwasher does not clean
Hi
Thanks
Rylee
Aug 04, 2009 | Kenmore Dishwashers
Dishwasher does not clean the dishes properly
Hi
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
I'm just wondering how much water should be in the dishwasher for proper cleaning? Should it cover the heating element?
Water level can depend on the model and manufacturer. The water will fill to the level of the float switch. This is a plastic looking thing near the front of the dishwasher along the tub bottom that looks like and upside down cup. The water level reaches a point to where the float lifts and activates a cut-off switch which will stop the water from filling, followed by the wash cycle beginning. Now, depending on where the heating element is located, the water level is usually just touching the element and not necessarilty covering it. Does this help you? If you still have questions, let me know.
Jan 01, 2009 | Kenmore 16372 / 16374 / 16379 Built-in...
Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
GE Nautilus 24" Built-in Dishwasher Logo
29 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
