My computer screen turns red whenever i put it on and stay that way until i angle the monitor
    Master:
    Sergeant:
  • 383 Answers
If it is a laptop, good luck
you might have to operate to check for bad connections
if it is a pc then check the pins on the vga cord on both ends for broken ...pins
hopefully that is all it is and you can just replace it
thats all i got
Posted on Oct 10, 2010
    Scholar:
  • 42 Answers
Most likely the physical connection. Make sure the wire connecting the monitor to the PC is firmly attached at both ends.
If that doesn't solve the problem, you should probably start saving now for a new monitor.
When I turn on my computer, the screen stays black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Gateway MX6956 Notebook
My monitor wont stay on.
May sound wierd, but Its windows, try going into safe mode, and changing the screen size, (1024 x 768) sometimes, it gets put on a size that doesnt fit your pc/screen, so it turns off.. Like I said, go into safe mode, and change it around and reboot untill it works.. I had that issue once.
May 23, 2009 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Bebq monitor Q7T4 17 INCH
If you can check your monitor with another computer, that would be the best inspection and make sure that the problem is from LCD monitors. The following steps are how to check what wrong with your monitor.
1. Power on both CPU and monitor. After it goes off, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely.
2.If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken and it is very easy to replace.
3.If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 13, 2008 | BenQ FP791 17" LCD Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After going blank, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 23, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
