Question about Olevia 332V LCD TV
Hi i dont have the typical antenna connection on the back of my olevia (not tv ready but is a hdtv model), what must i aquire in order to recieve OTR signals? thanks
Did you get this problem solved? I have the same problem too with the same tv.
Posted on Nov 16, 2010
  • chandansrs Nov 16, 2010
    I ve got the same problem with the same tv. Did you get a solution to it?
Turns on to olevia screen but then just flashes the olevia logo
Just check the input connection. Check it connected with external antenna. Check its input selection. Refer the user manual for details.
Feb 26, 2013 | Olevia 26" 226-t11 hdtv widescreen lcd tv...
No antenna port for Olevia TV How do I connect outside antenna to Olevia monitor
you will have to use a VCR, DVD player that has a built in tuner, or an HD converter box. The HD converter box will have an antenna connection for the outside antenna. But will also have RCA outputs to connect your TV to the converter
Feb 05, 2013 | Olevia 237T 37 in. LCD TV
How do you autoscan the olevia 232 t lcd hdtv? I connected an antenna and using a uneversal remote. it just sits there displaying 'no signal'
In the remote, select the input as antenna. It might be now lying as some other input. Normally the TV itself searches for channels. If it is not, go to menu in the remote control, select install-auto and press ok.
Jul 04, 2012 | Olevia LT37HVS 37 in. LCD HDTV
I have an olevia 532 b12 model and no tv channels in list
I have an olevia 532 b12 model. I do have cable at my house, straight to tv , no cable box.. but my tv only says a message ''no channels in list'' on the Turner source option. I Just bought this TV with no manual, What do I do in order to see the channels , to me it seems like the remote is locked. I cant change the time date , nothing ? The DVD playes plays and sounds great,,, Its just the cable TV part
Thanks
Apr 12, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
No channels
try this: there should be an area in the menu to switch between cable and antenna switch to the antenna and rescan in the channels and if you have the antenna that has a plug make sure it's plugged in also...
Dec 01, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 337-B11 how to connect to a TV
Unfortunately, This hdtv can only use with receiver. There is no cable connection back of it. You may connect it using with HDMI cable.
Nov 30, 2008 | Olevia LT37HVS 37 in. LCD HDTV
HD screen
You should verify that you are not just simply losing reception from a fault in the antenna.
If the signal is okay from the antenna, it is possible that the TV is having a failure in its tuner or IF sectons just to mention a starting point.
Jerry G.
Apr 20, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Hcn4226w
You can get the entire service manual 157 pages for your set that has all the info at the following site for 15.99 they email within 10 minutes of recieving the order and even provide free support to help you with your diagnosis and repairs. I have used them many times. here is the link.
http://servicemanuals.vstore.ca/
Mar 03, 2008 | Samsung HCN4226W 42" Rear Projection...
Olevia 332V LCD TV Logo
263 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
