Question about Kenmore 73952 Gas Dryer
Auto Dry not advancing
Kenmore model# 110.70812990
When set to auto dry, the dryer will heat properly but the knob will not advance at all to allow shut off.
The knob does advance in timer, but somewhat slow and will take longer than the current time, but eventually will end the cycle properly.
All other operations are working properly as far as the dryer shutting off when door is opened or when knob is moved to off position.
Have checked for an inline fuse only to see none in existance unless there is some sort of fuse inside the knob housing.
  • don0017 May 30, 2008
    Sry...Meant to type in inline resistor
    Novelist:
  • 161 Answers
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
Posted on Jun 29, 2008
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
The drum on my dryer will turn when I set the timer to any setting, but the timer does not work, nor does it heat up. Any suggestions?
See if the timer advances in the timed dry or the auto dry cycles. If the timer advances in timed dry but not in auto dry, then you could have a wire connection failure in the orange wire from the heating element to the timer.
If the timer will not advance in either type of cycle, then I recommend checking the timer part number that you are using.
Jan 07, 2011 | Estate EED4300TQ Electric Dryer
I have an older Kenmore 70 Series Dryer, but when I set the timer to dry it doesn't move, it stays in the same place. Any ideas?
do you have heat in the dryer?is it on time dry or auto dry?when the heat shuts down then the timer will advance in auto, when the heat starts again the timer stops.let me know if you have heat or not and send the model next time,will start with 110. or something like that and eight numbers after the dot
Aug 29, 2010 | Kenmore Dryers
Problem with Dryer Timer or heating element
The heat cycle must be working for the timer to advance in the Auto Dry setting.
Your heating element and or high limit thermostat is bad.
We need a complete model number to be more specific.
May 31, 2010 | Kenmore 600 6965 Electric Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Timer does not advance, dryer keeps running.
in auto dry the timer motor receives voltage to advance by way of the cycling thermostat.[each time the thermostat opens to stop the heat the switch in the thermo then changes that voltage up to the timer and it will advance timer motor until it closes again for heat and this continues till clothes are dry]so as long as timer is receiving that voltage and not advancing then i agree its the timer.other wise it could be a failing/intermident cycling thermostat.a thought.in timed dry the timer motor receives constant voltage.so if never stalls in timed dry it may be a clue that the timer is ok. i hope this helps you understand whats going on. God bless ,tom
Jan 23, 2009 | Dryers
DRYER DOES NOT DRY BUT CONTINUOUSLY RUN
Run the dryer for a minute, then open the door and check for heat. If there is heat, the element is ok. If so, you've got a venting issue. If there is a restriction in the vent you won't be able to get as much air out, therefore you won't be able to get as much of the moisture trapped in the air out. The auto dry settings on some dryers require the operating thermostat to open to advance the timer. If there is a venting issue it may cause the dryer to cycle with the hi-limit thermostat instead. Of course, it should not affect the timed dry cycle. so if it won't advance there either you may have another issue. Try taking the vent off the back of the dryer and allow it to vent into the room. This may take care of both of your issues if the restriction is in the home venting, then you would need to sweep the home vent. It's also possible that the restriction is in the dryer blower housing. Without the vent hooked up, turn the dryer on and feel where the vent leaves the dryer. You should have a fairly strong movement of air, if not you'll need to disassemble the dryer and remove the restriction.
Jul 21, 2008 | Kenmore Dryers
Kenmore 73952 Gas Dryer Logo
432 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
