Question about Toshiba SD-5970 DVD Player
Cannot get cd out. I think the dvd player is broken for good and the cd is stuck in the player. the only button that works is the on and off button.
    Scholar:
  • 143 Answers
Look for a small hole... if there is one, use a paperclip to press in the hole. It should help eject the CD. If that won't work and you are trashing the DVD player, you can always force the drawer open to get your CD out. Just pull on it or pry it open. You'll most likely break the track... so be prepared to trash it! OR you could take the screws out and take the unit apart... then you can get the CD out that way.
Posted on Oct 10, 2010
Testimonial: "I ended up prying the think open. Thanks so much. "
My jensen dvd player mvb85
It still plays but no sound... probably the line going to the screen, but check the settings and try a CD that worked before....
Keep me posted...
Feb 06, 2008 | Jensen 8.5" Overhead DVD Player Package...
A disk is stuck in my Harmon Kardon player. The door will open and close and I can see the disk but cant' get it out.
turn on the unit and then tried to press the play button while the cd tray is in place. if doesn't work, unplug the dvd player then open the cover to access the internal part. look for a broken limit switch for cd tray mechanical assembly or check weather the cd not in proper place in the tray that is why an error occur.
Sep 02, 2012 | Televison & Video
Sony DVD Player not working
The controller board is slowly dying. I think it might be time to buy a new DVD player.
Aug 19, 2012 | Sony DVP SR510H - DVD player
Cd player doesn't work
You can see a small pinhole near your CD Eject button on your CD Drive. Insert a blunt pin into it and push. The drive shall open!
May 31, 2012 | 2002 Volvo V70
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
My dvd tray is stuck...I think it's a dvd stuck in the tray
unplug the player for 5-10 min...once you plug it back and power on quickly tap the open/close button (the player by default will try to load the disc)
feel free to rate help
Jun 26, 2010 | Yamaha DVD-C996 DVD Player
CD is stuck and eject button doesn't work
Unplug the cd player and open the unit up by taking the top cover off..there will be screws holding it on on the underside. You should be able to retrieve the cd from inside. Your track is broken, you will need to replace it.
Jun 01, 2009 | Pioneer DEH-P3100 CD Player
After approx 1/2 hour of play the movie gets stuck for few seconds, plays again for 2-10 seconds, then permanently gets stuck. Sometimes a smack to the machine works, ff does not work....we usually just...
Smacking the machine is a good way to destroy the DVD lens. Get a CD/DVD lens cleaner and make sure there aren't any marks on the disk. Dirt & smudges cause about 75% of all CD/DVD player problems.
Feb 27, 2009 | Toshiba SD-2150 DVD Player
DVD+VCR doesn't work
good evening,
my name ahmed , your question is DVD+VER doesn't work.
anser:- your dvd in that before power button pressing you one are two time shake or move in side some ma sine stuck .after that you power button press and Shaka and se other wise any sk ru driver take and open and where we keep cd there check some stuck will be that's shake one time and close.again try.if not came send me your ? my name ahmed687 please send me only your ?and accept my answer
ahmed687
Jan 03, 2008 | GoVideo DVR5100 DVD Player / VCR Combo
Toshiba SD-5970 DVD Player Logo
143 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
