Question about We Pistol Lazer Sight Silver Laser Scope Glock Ruger Colt
Can't get my Glock 37 45 Gap clip loaded even with the tool that came with it, is there another way to load this clip?
  • 243 Answers
The UpLULA is the best tool I have found for this job. Works on 99% of pistol magazines. Works great on my glock 19.
BTW, the term "clip" and "magazine" do not interchange. A clip is a ammunition holding device that feeds ammunition into a magazine, A magazine is an ammunition feeding device, and typically contains a spring.
A good explanation is available here.
Your Glock has a magazine.
Posted on Oct 14, 2010
How do I get the clips off a washing machine filter?
The clip secures the SUMP HOSE which has the filter in it ,Put an old towel under this and give it a tap with a flat bladed screwdriver this will loosen the White clips that hold on the hose,then you remove filter and clean noting which way it came out , refit
May 08, 2014 | Hotpoint Aquarius WD640 Front Load...
Door not closing all the way shut
top of the door hinge has a collar with holes drilled in it. there is or should be a roll pin in one of the holes which stops against a vertical pin. there is a torque rod in the door and this stop loads up like a spring as the door is opened to push the door closed. the torque rod is made to load up in either direction so they are compatible with left or right swing doors. they make a special tool for turning the collar and getting torque load but you can get it done with a small punch or two or even a couple of allen wrenches that will fit in the collar holes. you have to turn the collar to load up the torque rod and install the roll pin where it will do the most good. DO NOT put too much load on the rod it CAN and WILL break in the door. I usually open the door until I get a 3 or 4 inch gap and make sure it will close on its own from there. It usually only involves moving the collar two or three hole spots from neutral torque. If you cant get any torque or if it starts to load up and slips in the door than the rod is bad or the socket it sits in is stripped out.
Mar 28, 2014 | True GDM-23 Refrigerator
I purchased a S&W sd40 ve the clips rattle when loaded? not happy about it?
Common problem with these clips. I just bought a new SD40 yesterday and both clips rattle. Nothing you can really do. I read on a forum where a guy swapped the lower place and spring from a glock 23 clip and it fixed it.
Jan 09, 2013 | Smith & Wesson Watches
Where can I get hold of a Ctc Laser Grip Glock 17/22/24/31/34/35?
Thereare several sites online that sell the Ctc Laser Grip Glock 17/22/24/31/34/35. Try shopping around as prices can reallyvary. Here's a link to one site that I found http://www.lasersightsforhandguns.com/crimson-trace-laser-grip-lg-617-glock-17-22-24-31-34-35.html
Jul 17, 2012 | Crimson Trace Ctc Lasergrip Glk...
Glock password
ketika saya membuka aplikasi glock, tiba2 di minta passwordnya sama saya, dan yg anehnya hp saya tdk bisa keluar dri aplikasi tersebut, dan kalau saya matikan lalu saya hidupkan kembali hp saya mk aplikasi itu muncul kembali dlm keadaan meminta pasworrd. yg saya ingin tanykan apa bunyi password itu , terima kasih
May 14, 2012 | Cell Phones
How do remove the window crank so i can remove the door panel?
There is a little clip behind the crank where it goes thru the panel. the clip looks like a "C" shaped clip..you'll need a small pick or screwdriver to pop it out..there is a tool specially made for this and can be rented fron autozone...once the clip is off crank pulls right off...when re-installing..put clip back on the crank , place crank over shaft, and press on till you hear it click.......ps..be careful as to not lose the clip...it's spring loaded and may go flying when you pop it off...if you do lose it they are readily available
Jan 20, 2011 | 1994 Buick Skylark
How do you get to the latch ? The back part of the top of the washer lifts up but can't get the front to lift.
The front is probably held down with some snap clips, try wedging something in the gap and bumping it.
Jan 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do you get the back off a men's armitron watch to change the battery? Took it to Walmart and they can't figure it out.
If you don't have a watch repair kit, a small flathead screwdriver or even a butter knife would work. Set the watch face down on a soft material (pillow/towel). Insert the flat tool in the gap between the back and the watch itself. Apply a bit a of pressure the loosen and remove the back. Remove the rubber gasket covering the battery. Then you will want to remove the clip covering the battery (with the flat tool). Once the clip is removed flip it upside down and let the battery fall out
Nov 29, 2009 | Watches
Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
May 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Open Questions:
Is it a Webley or a Eley Colt .455? How to tell if the cylinder bore has been modified to accept Colt 45 or other ammunition. Obvious the barrel (8" smooth bore) and sights were replaced Please help an ole man out that happens to know "Nothing" about Colt Double Action Revolvers... At 66 I guess it's never to late to own a Colt! Is it a Webly or Eley .455 ? and How can I tell if it's been reworked to accept Colt 45 ammunition? As many details as I have are below. Any body know just what I have here? I think I have a 1914?? British .455 Colt New Service Revolver. Has some standard factory Colt proof marks along with British proof marks. Colt logo above the grips on the rear left side of frame, VP inside a triangle on the front left side of trigger guard, and a #3 on the rear of trigger guard same side. Has had the orig. barrel replaced with a stainless steel 8" smooth bore pinned barrel. British proof marks on 3 different places on the revolver. On the breech area, the rear of the cylinder, and inspection and acceptance markings On the left rear of the frame (just below the hammer). Broad arrow government acceptance mark on top. Under that is a Crown Under that is F9 E Bone grips that look like they are orig. also. A large #7 is stamped "under" the serial number at the crane too, and the grips are also marked with the #7 in pencil underneath on both grips. On the left side of the frame under the grips is stamped the capital letter "E", so I know originally it was chambered .455. Highly polished mirror like blue finish on the original frame. Has a lanyard swivel on the bottom of the frame and has "No markings, lettering or numbers on the frame"by the lanyard swivel. Any Help/Feedback is Greatly Appreciated Thanks in Advance!
Nov 19, 2017 | The Optics
See all We Pistol Lazer Sight Silver Laser Scope Glock Questions
We Pistol Lazer Sight Silver Laser Scope Glock Ruger Colt Logo
220 people viewed this question
Top We Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a We Optic Expert? Answer questions, earn points and help others
