Question about Craftsman Garden
I just obtain a mulcher Eadge 1 6.1/5 H.P. Does this mulcher works only with gasolie, or I need to mix whith oil?
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. If there is a spot where you add and check the oil it doesn't need mix if it doesn't then you will need to mix the gas.
Posted on Oct 10, 2010
What type of oil is used for my 2055 2.O CI woodsman chain saw?
This engine is certified to operate on unleaded gasoline.Before operation,gasoline must be mixed with a good quality synthetic
2-cycle air-cooled engine oil designed to be mixed at a ratio of 40:1.Poulan/Weed Eater brand synthetic oil is recommended.Mix
gasoline and oil at a ratio of40:1.A 40:1ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline.
As far as bar and chain oil:
Genuine Poulan R bar and chain oil is recommended to protect your unit against excessive wear from heat and friction.Poulan R oil resists high temperature thinning.If Poulan R is not available,use a
good grade SAE30 oil. Never use waste oil for bar and chain lubrication.
Oct 20, 2014 | Garden
Hison jet ski
doesnt it have an oil tank and pump and manage its own mixing?
Aug 09, 2014 | 2-cycle Engine Oil 2-m Case Of 4 Gallons
What type of gas to use in a craftsman edger 358.773110
FUELING ENGINE This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality 2-cycle air*cooled engine oil. We recommend Craftsman brand oil. Mix gasoline and oil at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline). DO NOT use automotive oil or boat oil. These oils will cause engine damage. When mixing fuel, follow instructions printed on container. Once oil is added to gasoline, shake container momentarily to assure that the fuel is thoroughly mixed. Always read and follow the safety rules relating to fuel before fueling your unit.
Sep 12, 2011 | Craftsman Garden
Fuel/oil mixture
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
From Poulan website:
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas. If you have other brands of equipment that require different fuel/oil ratios and you don't want to mix separate fuel cans, you should use the lowest numerical ratio. For example, if you have products requiring 40:1, 50:1, and 32:1 ratios you should use the 32:1 ratio for all products. This may cause slight smoke increase in the exhaust in the 40:1 and 50:1 products due to more oil in the fuel, but it won't damage either of the engines.
Aug 15, 2011 | Poulan Garden
What ratio of gas to oil goes into my weedwhipper
They are usually 40 to 1 ratio. Mix 3.2 ounces of 2 cycle oil in 2 gallons of gas.
Jul 15, 2011 | Garden
What fuel does my strimmer require - McCulloch 240
Most trimmers require a mix of regular unleaded fuel and two cycle oil...the ratio is usually 50:1...you can purchase the oil in convienient packages that allow you to add the whole package to 1 gallon of fuel to obtain the proper mix
Apr 24, 2011 | McCulloch Trimmer Plus Attachment: Add On...
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the proper fuel mix for a mcculloch ms1635 chain saw?
between 32:1 and 40:1 - Manufacturer recommends 40:1 Ratio - EXAMPLE: "Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio."
Sep 02, 2010 | McCulloch Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
mixed with a good quality synthetic 2-cycle
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Garden Logo
82 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
