Question about Samsung LN-T4061F 40 in. LCD HDTV
Hi, I have a samsung LNT4661FX/XAC its been around 3 years.. Recently there are a bunch of red dots appearing on the screen no matter what channel or input its on.. they stay there even if I close it and reopen it! The only way to temporarly remove them is to unplug the enitre tv and then replug and start it.. But they always return! And slowly slowly they are becoming more and more.. Is there a way to fix this or imy only option is sending it for repairs? Thanks a lot!!
techman
  • 3130 Answers
SOURCE: Little red dots
The driver board is going bad it sounds like and if you do not call up and get it fixed under warranty, as it should still be under a warranty, then its going to be a nice hefty repair bill. Good Luck Ps Please dont forget to rate this thread
Posted on Oct 19, 2006
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
  • 98 Answers
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Posted on Feb 06, 2009
  • 197 Answers
SOURCE: I can't find our model anywhere!
no
Posted on Jun 07, 2009
SOURCE: Samsung Plasma TV
I have this problem too. I have had a technician over to service it twice already and I picked up on a few things he did to fix it. Here is what I learned. the raining pixels has to do with the timing in the circuit boards. Basically telling them when to turn on and off. I would only recomend this solution if you are technically inclined. Remove the back from your tv on the left upper quadrant you should see a small gray dial with marks that a Philips screw driver would fit it. There are three or four of these on the boards scatter across the tv. Each on corresponds to the colors firing in sequence. Take your Philips and turn it to either extream. You should see a your screen go crazy with whatever color corresponds to the dial. Then ever so slowly turn the dial undtil you don't see any more flickering. Do that with each dial and you should be able to get rid of most of the flickering. on the right side of the there is a panel underneath the support bar with orange adjuster. I don't know what they do but they also help reduce the flickering. A word of caution. If you can use something non metallic to adjust these dials. There is a small metal lip to keep the dial from turning too far. If your screw driver touches it. It will fry the dial and your screen will blink red/yellow or blue. and you will have to buy a new board. Luckily they are only about 30 bucks, but I learned the hard way.
Posted on Jun 24, 2009
Red dots all over my screen
try to check the t-con board if it is lcd tv..If it is acrt tv ,try to check the transitor drivers for the RGB located at the back of the tube
Mar 17, 2014 | Televison & Video
I have a red and green dot in the middle of my screen that will not go away and doesn't change no matter what ever channel you watch
if you remove the rear cover you will find 3 large lens----with the set on cover the red and then the green one at a time, if the dots vanish you have a "burnt" picture tube caused by some problem in the set---it is permanent damage and not only would the picture tubes have to be replaced but whatever arced and burnt them would have to be located and repaired.
If the dots go away it is most likely not worth fixing.
SD TECH
Apr 06, 2011 | Mitsubishi WS-65809 65" Rear Projection...
White dots all over the screen
White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue.
Please contact nearest Samsung service center or local tv repair shop for repair estimate.
Thanks.
May 16, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Purple dots on HD LCD samsung model LNT4661FX/XAA when on.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 27, 2010 | Samsung LNT4642H 46 in. LCD Television
http://www.youtube.com/watch?v=Mm51C_RDIZE
-and-
http://www.youtube.com/watch?v=BNHHrgX_6cs
Jan 27, 2010 | Samsung Televison & Video
Samsung le40m71 Flat screen ''Red Screen'' Error
I do have the same problem and has - sadly - been told by the repair shop, that they know the fault, but they can't find the spare part... lol
Jan 13, 2010 | Televison & Video
LE40R74BD VOLUME OK BUT BLANK SCREEN
sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swolled on top and are easy to solder in cost about $1 EACH
Jul 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
The tv will not turn on.
hi right now samsung is the best tv maker out right these problem dont happen with samsung what would be good to do is call them and let them know your problem cause you have a year protection on it thats if it less than a year
Jan 10, 2009 | Samsung 40 in. Flat-Panel LCD HDTV
Samsung LN-T4061F 40 in. LCD HDTV Logo
373 people viewed this question
Jerry Greenberg
Jerry Greenberg
