Question about Kenmore Dryers
I have a kenmore 110.79722800 gas dryer. It used to simply buzz when I pushed the start button and I would have to manually turn the drum while holding the door switch to get it started. It has since stopped buzzing and will not start at all. Any ideas what needs to be fixed?
Kenmore Gas Dryer Model # 110.79722800 timer will not advance in any position dryer work and heats fine just won't turn off when done.
Posted on Mar 27, 2011
Start switch buzzes and won't start the dryer
I had possibly a similar problem with a Kenmore 90 electric dryer. Sometimes pushing the start button would just make a buzzing sound, but the drum would not turn.
I ended up replacing the motor and so far it seems to start up smoother and quicker. In the process of taking it apart, there was a surprising amount of lint piled up in front of the blower intake. This is after the lint screen and not really possible to get to without taking off the lower front panel and then removing the duct to the blower. Perhaps it was dragging on the blower and causing the motor to overheat. Worth looking at first, perhaps.
Apr 01, 2014 | Kenmore 73952 Gas Dryer
I have a kenmore problem with the Kenmore Dryer Model 110.79722800 gas dryer. It used to simply buzz when I pushed the start button and I would have to manually turn the drum while holding the door switch...
The motor has gone bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 10, 2010 | Kenmore Dryers
Basic order of troubleshoot - gas dryer, electric on (light on when opened), won't rotate or start, hear buzzing when pushing button. No section for Kenmore 70901 gas dryer on this site. I want basic order...
Buzzing as in end cycle tone? That would indicate a stuck switch on the motor and freeing it would buy time until new motor could be installed. Low humm as in motor is stuck and cannot turn would require removing belt and see if motor is stuck, drum is stuck or something in exhaust fan holding it back.
Eric
Jun 11, 2010 | Kenmore Dryers
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Kenmore 80 Series Gas Dryer won't run unless empty
MORE THAN LIKELY YOUR TENSION PULLEY IS SHOT WAS IT MAKING ANY SQUEEKING NOISES
Aug 26, 2009 | Kenmore 73952 Gas Dryer
Dryer won't start
The problem is likely a malfunctioning centrifugal start switch in the motor.
More info, let me know.
Charlie
Aug 20, 2009 | Kenmore Dryers
Dryer drum will not turn.
Hello.
If the buzz continues to go for awhile(2-3 minutes before you stop it you will need to replace the belt on your dryer.
If the buzz quits pretty quickly after you let go of the start button and you smell something hot or electrical, you will need to replace the motor.
Please let me know if you have any other questions.
Jul 22, 2009 | Kenmore 94052 Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Drum wont turn
Is your motor working? How about your belt? Is it broken?
Jan 24, 2009 | Dryers
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Dryers Logo
155 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
