Question about Roxio Easy Media Creator 9 Suite (227100) Full Version for PC
In roxio 10 suite when I start the classic view for a data burn ..Roxio start trying to install the update manager. A total pain.
    Master:
    Sergeant:
  • 383 Answers
Open your task manager find the process that is trying to update, remember the name, stop the process and then search for it in your c:\ directory and delete it maybe that will work
Posted on Oct 10, 2010
Disc
It may be a conflict with another program. Roxio is a little tempramental about other software.
You can try another Burning software to check the drive is not faulty.
You can try a free program like IMGburn.
If that program works i would uninstall roxio, run a registry cleaner. I like CC cleaner's built in registry cleaner.
Then re install roxio and check the roxio site for any updates
Jul 11, 2010 | Roxio Easy Media Creator 10 Suite
Roxio Creator Classic 6.2.0.110; after dragging doc into data field and clicking the burn icon, message appears: "There are no supported recorders available. Make sure that your recorder is powered on...
well i would go out to the roxio web page and select either tech support or look for drivers and downloads, this is the only way you can be assured you have the most up to date drivers. sometimes the cd's are shipped with outdated drivers. follow the prompts it may delete the old drivers or just update them. then power your machine off wait 12 seconds and then reboot and try again. it is frustratring i know but you need to reboot to update your machine
Jun 01, 2010 | Roxio Easy Media Creator 7.5 for PC
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
I lost my roxio 10 numbers
Uninstall the software.
Access http://www.MajorGeeks.com
and download/install the "Ashampoo Burning 6 Free Edition" software.
It is *FREE* software that works better than ROXIO.
Mar 26, 2010 | Roxio Easy Media Creator 10 Suite
When I start up windows XP - used for many years satisfactorily, it now tries to start a utility to install Windows Update manager for Roxio. This started suddenly for sume reason about a month ago and at...
It sounds like something in your Startup menu, that wasn't uninstalled. This is a problem, because it can be named anything, and you probably won't recognize it. Unless you can find someone that has had the exact same problem, and identified the process, you will have to try to restore your computer to a date previous to that when the problem started occuring. That would be the easiest fix. If that doesn't work, you might try googling the problem, you might get lucky and find someone that's figured it out. Last resort, of course, is to reload XP. Good luck, I know your pain, been there.
Mar 21, 2010 | Computers & Internet
In Roxio Creator 2010 slideshow won't open..complaining " Certificate file is missing or has been corrupted". Reinstaling does not help
Hi.
Check that the date on your computer is correct. Certificates are checked on an online microsoft database. If your computer has date Jan.2001, you get the certificate error.
If that was not the problem, then try the following:
Go to Control pane, switch it to classic view.
Open Control Panel ->Appearance and Personalization->Folder Options->View , then click on "Show Hidden files and folders" and Apply or OK
Go to : c:\Program Data
Delete folder called Roxio & Sonic
Try starting Roxio Creator.
If still no luck , do a system restore to a date that is one or two days before you tried to install Roxio.
After system restore, log in from account with administrator privileges, and reinstall Roxio.
When you reinstall Roxio, instead of double clicking on installer file, try clicking right mouse button on setup file and choose "Run as Administrator" from dropdown menu.
Allow all requests to allow system changes when asked.
Regards.
Nov 07, 2009 | Computers & Internet
Roxio help
download the latest version of roxio viz roxio creator 10 (if you dont have it) .. disc copier is available in that..
Jul 10, 2009 | Roxio Easy CD & DVD Creator Platinum...
I get an error in Creator Classic
I'm not sure what the problem is. Does it happen regularly? If it is regular make a note of any actions you take before the error occurs.
Check to see whether you have the latest updates for your software.
Also check on line to see whether any other uses have a similar problem check on any forums...
Roxio may have their own forums or be able to assist with your query.
Failing this you may solve this by uninstalling the software and reinstall it this may do the trick.
Kind regards
Alleluia
Nov 21, 2008 | Roxio Easy Media Creator 10 Suite
EZCD 5.0 and EZCD 6.0
I don't think that 6 and 5 are compatible 6 is an upgrade from 5. I have just 5 on one of my old XP computers and it works fine, but that's all I have. I went to the website and they are not giving any support for Roxio 6 anymore.
I will tell you that Roxio Easy Media Creator is fantastic. The things you can do with that are unbelieveable. I got it at Sam's Club for about $70. But I know that does not solve your problem.
Roxio 5
To burn data files, Open project selector, make a data cd, click data cd project. WhenEasy CD Creator 5 opens and you choose your files to burn, try this: Select Disc at Once Radio button, click okay and click burn.
ID Number: 000008GN Products: General Information
OS: Issue When burning a CD or DVD, you receive an error, burning does not complete, or your media is rejected. Resolution Burning errors can happen for a variety of reasons. Roxio has found that doing the following steps resolves about 80% of all burning issues. Please give all these steps a try and see if it fixes your writing problems.
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. The media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  5. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  6. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Roxio 6
OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: EE6000132 Products: Easy CD Creator 6.x Platinum Suite
OS: Windows 98 Second Edition
Windows ME
Windows 2000 Professional
Windows XP Home Edition
Windows XP Professional Edition
Issue Roxio does not recognize the blank CD/DVD media in the recorder drive.
Resolution Follow the listed procedure to ensure that the CD/DVD media you are using is supported by your CD/DVD Recorder.
On Easy CD and DVD Creator:
  1. Open Creator Classic.
    1. Launch Roxio Easy CD & DVD Creator 6.
    2. Click on the Creator Classic icon.
  2. Check the supported media types.
    1. Click on Tools on the top left hand corner of the window, then select Drive Properties.
    2. Under the Devices section, click on your CD/DVD Recorder drive.
    3. Under Supported Media, click on down arrow to see a list of supported media your CD/DVD Recorder supports.
    4. Ensure that media type that you are using is listed here. If it is not listed then your CD/DVD Recorder does not support that type of media.
On Easy Media Creator:
  1. Launch Disc Information.
    1. Launch Roxio Creator Home menu.
    2. Click on the Tools tab, then select Disc Information.
    1. Under Supported Media, ensure the media type is listed.
    • Reboot.
I do know if you have Roxio5 you cannot installed Nero 6 InCD, not compatible. Other than all of the above, I have no more suggestions. I am really sorry, wish I could work on your computer to figure out the problem. This is my specialty. Reloading computer and figuring out problems. It is so much easier hands on.
Good Luck
Mar 30, 2008 | Roxio Easy CD & DVD Creator 6...
Roxio Easy Media Creator 9 Suite (227100) Full Version for PC Logo
55 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
