Laptop monitor will not come on.
Cyberpower 17 in., AMD 64x2, 2 gb. ram, nvidia 7600 GO force graphics.
Installed new 200 gb 7200 hard drive, and partitioned for dual boot.
Installed win xp pro and all drivers with no problem.
Installed vista in other partition, began to install drivers but vista would not read the disk. So I began downloading drivers from the internet and no problems until I got to the graphics driver.
Download with no problem but when time to reboot the monitor never came back on.
I hear noise and everything seems to work but no monitor.
After about a week of messing with it, I reinstalled the original hard drive and powered on, everything works except for the monitor. I hear the windows xp startup sounds, I hear all normal sounds, I can even put a dvd in and hear the sounds of the movie but no monitor.
I've tried an external monitor with no results.
Now the crazy thing is every now and then mabye 2 or 3 days with no power supply to the laptop the monitor comes on, but if I reboot no monitor again.
Any ideas.
thosnv
  • 5 more comments
  • thosnv May 30, 2008
    It was probably made by ASUS, because checking the motherboards ASUS seems to have used the same. As far as settings, I have it set to hibernate when the lid is closed. This also works normal as when I close it up the orange light flashes normally and when I open back up and push the power button everything comes on normally except the monitor. So far I can't find a button for the monitor. I will try the bios if I can ever get to see what is on the monitor.
    I checked all the connections I could think of. Component failure mabye i just hope not.
    Warranty out 3 months ago. Took it to a repair shop, all they could come up with is replace motherboard but could not find one. So I don't have to much to lose but I really don't think it is a motherboard failure.
    I have done this when I turn it off. The monitor came on a couple of days ago and I was going to just leave the computer on for awhile to see if I could find something but windows downloaded an update and rebooted and I haven't got the monitor working again yet.
    Alright, this is crazy. This time I pushed the Fn F2 button, switch the display output, pushed the power button down until windows shutdown, unplugged the power supply and took out the battery for appx. 10 min, put the battery back in with no power adapter plugged in, and now the monitor is on.
    Now I am afraid to shut the computer down.
    Any input on what to do while I can see what I am doing.
  • thosnv May 31, 2008
    You know what I would like to do is take the cmos battery out and reinstall it but I don't where it is located. I have taken out memory, keyboard, hard drive, wireless chip and no luck finding it.
  • thosnv Jun 03, 2008
    Not solved yet. Spent the weekend searching for the right bios with no luck. While the laptop was working this weekend I tried to find anything wrong I could think of with no luck. I tried to update the graphics driver to see if that would override any problems, but when time to reboot the monitor did not come back on. Back to square one to see if I can get it to come back on.
    Sergeant:
  • 458 Answers
The next time you get it to come on, try the refresh rate. Have you tried to flash the BIOS? You can download the BIOS from the same place that you got the drivers. What brand of laptop is this? Cyberpower,DEL,HP,COMPAQ,ALIENWARE,
GATEWAY etc. does not build laptops. They just put their name on them, because they have another company set them up to their specs. ASUS is mentioned on their site. This tells me that ASUS might have built the laptop. ASUS is the best laptop company. I have never had any problem with my ASUS laptop that I built. Try flashing the BIOS, or check the BIOS settings. This is very strange. You can also check the button by the latch and see if it is sticking. This button turns on the monitor. I have seen that button stick on laptops. It should pop up when the laptop opens. You might have to look at the manual to find the button. Check your settings on what the monitor does when you close the laptop. It could be in sleep mode or hibernation and might be stuck in that setting. These settings are also in your BIOS. Hit the DEL button or one of you F buttons to get into the BIOS. ASUS uses the DEL button.
Posted on May 30, 2008
  • 1 more comment
  • T&N Family Electronics Dean and Sherrie Terrell
    Have you tried to put the settings in stay on always mode? I always do this to my machines and use the screen saver. The C-MOS batttery might be on the board near the wireless chip. I would be leary on taking it out. I would usually say this but the last time that I did this with an IBM it locked up the BIOS on me and kept asking for a password. Some have an ATMEL chip in them to stop anyone from being able to steal it.
    Did I mention trying to flash the BIOS. That would be the next thing to try. Keep me updated and I will try to help you figure it out.
    Is this solved or not? The person has not rated this yet.
    Have you tried this with an external monitor yet?
    Will it boot up with power at all now?
    Have you tried to hit F8 when it boots up to go to safe mode?
    Sorry for the time for a response. The webmail server keeps going out on the fixya web site and sometimes it does not let us know that you replied again.
  • 13,433 Answers
This may be a loose connection or possible component failure.
Would need to take a look into the laptop myself to see what the problem really is.
I can suggest you take a look on the connectors - hdd & lcd, since this started when you changed the hdd thats why Im recommend you check those connectors also, maybe reconnect.
  • 3 more comments
  • Ekse May 30, 2008
    well theres a good suggestion by cellphoneer try that also.
  • Ekse May 30, 2008
    Be carefull if you decide to flash the laptop bios. wont be that easy to recover incase it fails somehow.
  • Ekse May 30, 2008
    id be more than happy to take a look at the laptop but Im in finland, maybe you should take the laptop to your dealer to be tested, it seems quite new I suppose you still have warranty on it?
  • Ekse May 30, 2008
    yeah these days its all about replaceing the whole board hardly no one does real repairs these days.
  • Ekse May 31, 2008
    Seems that you basicly removed the laptop down from external power sources, it only had the bios 3v battery in there.
    A good "Hard" reboot. - I wonder if that does the trick?
    You could do a stress test and push the laptop to the limit to see if it crashes, on the other hand if it runs good even under stress, then I don't know whats going on. Play some heavy games on it for example.
    Scholar:
  • 173 Answers
Actually believe it or not this happend to me and i took out the batery for 5 minutes put it back in and it booted right up with the monitor finally working, try this and let me kwno if it works, it may be easier to fix than you thought
Graphics card
you cant install a graphics card on a laptop, especially latest models, its all built-in and you need to replace one of your RAM
Mar 17, 2014 | Computers & Internet
Hi my names robert england I was wondering if the the graphics card of my TOSHIBA Satellite C660D-14W can be replaced with a more heavy duty graphics card like a NVIDIA Ge-Force thanks.
Sadly graphics cards in Notebooks/Laptops cannot be replaced as the current graphics card is built into the motherboard, this is the downside of having a Notebook/Laptop as the only things you can really upgrade is the RAM or the Hard Disk Drive
Mar 28, 2011 | Computers & Internet
Sims 3 crashes
Hi. Well that is obvious if the memory as well as the virtual memory drops below the required level. Your VGA settings (Graphic Adapter) might also making the game crash. It is a good thing to disable AVG temporarily while you play the game. (Please let me know your System's specifications as well. Like RAM size, VGA size, Processor Speed and Hard Drive Capacity - Both free and used capacity. If you have default specs for the Dell I6400 no need to include). Otherwise it will use the memory and virtual memory to scan the activities of the game.
You have to keep some vacant area in your System Partition (In which you have install the Operating System). Virtual memory page file is 1.5 x the size of RAM. But you can increase the size. But you have to have a faster hard drive as well because it will be used more when you increase it. The other option is to upgrade your RAM (installing an additional RAM if the PC supports). Most of the modern games require way too high performance PCs. Most of the time RAM and VGA.
To increase the Virtual Memory:
  1. Right click on My Computer icon and go to Properties.
  2. Click on Advanced tab.
  3. Click on Settings under the category, Performance.
  4. Click on Advanced.
  5. Click on Change under Virtual Memory.
  6. Select a free Partition (Which had more than the size x 1.5 of your RAM)
  7. Select the option System Managed size if you do not wish to do it manually. If you want to configure manually, select the Custom size option and enter the size which I mentioned before in BOTH the boxes.
  8. Then click on SET.
  9. You may be asked to Reboot the machine. Do so if asked to.
  10. Then play he game.
  11. If possible please upgrade your RAM.
Sims 3 System Requirements are as follows:
  • FOR WINDOWS XP
  1. 2.0 GHz P4 processor or equivalent
  2. 1 GB RAM (512 should be enough however)
  3. 128 MB Video Card with support for Pixel Shader 2.0
  4. The latest version of DirectX 9.0c
  5. Microsoft Windows XP Service Pack 2
  6. This one is very important: At least 6.1 GB of hard drive space with at least 1 GB of additional space for custom content and saved games.
  • FOR WINDOWS VISTA
  1. 2.4 GHz P4 processor or equivalent
  2. 1.5 GB RAM
  3. 128 MB Video Card with support for Pixel Shader 2.0 (not enough)
  4. Microsoft Windows Vista Service Pack 1
  5. At least 6.1 GB of hard drive space with at least 1 GB of additional space for custom content and saved games
  6. For computers using built-in graphics chipsets under Windows, the game requires at least:
  • Intel Integrated Chipset, GMA 3-Series or above
  • 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
  • 0.5 GB additional RAM
  • FOR MAC OS X
  1. Mac OS X 10.5.7 Leopard or higher
  2. Intel Core Duo Processor
  3. 2 GB RAM
  4. ATI X1600 or Nvidia 7300 GT with 128 MB of Video RAM, or Intel Integrated GMA X3100.
  • This game will not run on PowerPC (G3/G4/G5) based Mac systems, or the GMA 950 class of integrated video cards.
Windows Supported Video Cards NVIDIA GeForce series FX 5900, FX 5950 6200, 6500, 6600, 6800 7200, 7300, 7600, 7800, 7900, 7950 8400, 8500, 8600, 8800 9300, 9400, 9500, 9600, 9800 G100, GT 120, GT 130, GTS 150 GTS 250, GTX 260, GTX 280, GTX 285, GTX 295 ATI Radeon™ series 9500, 9600, 9800 X300, X600, X700, X800, X850 X1300, X1600, X1800, X1900, X1950 2400, 2600, 2900 3450, 3650, 3850, 3870 4850, 4870
Intel® Graphics Media Accelerator (GMA) GMA 3-Series, GMA 4-Series
Laptop versions of these chipsets may work, but may run comparatively slower. Standalone cards that are installed in vanilla PCI slots (not PCIe or PCIx or AGP), such as some GeForce FX variants, will perform poorly.
Integrated chipsets such as the ATI Xpress and the NVIDIA TurboCache variants may default to settings that are higher than what would be optimal for them. Graphics settings can be lowered to improve performance.
The NVIDIA GeForce FX series is unsupported under Vista. MAC OS X Supported Video Cards NVIDIA GeForce series 7300, 7600 8600, 8800 9400M, 9600M GT GT 120, GT 130 ATI Radeon™ series X1600, X1900 2400, 2600 3870 4850, 4870 Intel® Graphics Media Accelerator (GMA) GMA 3-Series.
So make sure to meet at least the minimum requirements.
Enjoy Gaming.
Please feel free to ask anything related to this. Please rate the answer as well if you feel that it helped to solve the issue.
Thanks for contacting Fixya!
Jul 10, 2010 | Dell Inspiron 6400 Notebook
I have dell inspiron 1545 intel media graphics accelerator 4 series chip set family. i cant play good games like crysis, mass effect, assasins creed etc. what should i do to play it. anyone please help me?
Minimum System Requirements
OS – Windows XP or Windows Vista
Processor – 2.8 GHz or faster (XP) or 3.2 GHz or faster* (Vista)
Memory – 1.0 GB RAM (XP) or 1.5 GB RAM (Vista)
Video Card –256 MB**
Hard Drive – 12GB
Sound Card – DirectX 9.0c compatible
* Supported Processors: Intel Pentium 4 2.8 GHz (3.2 GHz for Vista) or faster, Intel Core 2.0 GHz (2.2 GHz for Vista) or faster, AMD Athlon 2800+ (3200+ for Vista) or faster.
** Supported chipsets: NVIDIA GeForce 6800 GT or greater; ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater. Laptop versions of these chipsets may work but are not supported. Integrated chipsets are not supported. Updates to your video and sound card drivers may be required.
Recommended System Requirements
OS – Windows XP / Vista
Processor – Intel Core 2 DUO @ 2.2GHz or AMD Athlon 64 X2 4400+
Memory – 2.0 GB RAM
GPU – NVIDIA GeForce 8800 GTS/640 or similar
Apr 01, 2010 | Dell Inspiron 1545 Notebook
DV6000 No Video on LCD screen
There is a very common issue with the HP DV60xx series overheating (due to the Nvidia video chip) that causes these laptop system boards to fail. There is a listing of the "affected models" http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=1842189&lang=en&docname=c01300427#c01300427_dv20
And based on your product number you may have an extended warranty. As far as I understand, this extended warranty is limited to AMD processor based units which use the NVIDIA GPU (graphical processing unit) .
I would check the link I posted above, see if your Product number (usually a white sticker on the bottom near your serial number) is on the list and then call hp.
Good luck :)
Sep 01, 2009 | HP Pavilion dv6000z Notebook
Cant get sims 3 to work on laptop
Could be your laptop doesn't have the necessary horsepower to run SIMS 3 (mine doesn't)
THE SIMS 3 MINIMUM HARDWARE REQUIREMENTS
FOR WINDOWS XP
* Windows XP (Service Pack 2)
* 2.0 GHz P4 processor or equivalent
* 1 GB RAM
* At least 6.5 GB of hard drive space with at least 1 GB additional space for custom content
* 128 MB Video Card with support for Pixel Shader 2.0
FOR WINDOWS VISTA
* Windows Vista (Service Pack 1)
* 2.4 GHz P4 processor or equivalent
* 1.5 GB RAM
For computers using built-in graphics chipsets, the game requires at least:
* Intel Integrated Chipset, GMA X3000 or above.
* 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
* 0.5 GB additional RAM
SUPPORTED VIDEO CARDS
FX 5900, FX 5950
6200, 6500, 6600, 6800,
9600, 9800, GTX 260, GTX 280
ATI Radeon™ series
9500, 9600, 9800
2400, 2600, 2900
3450, 3650, 3850, 3870,
4850, 4870
Intel® Extreme Graphics
GMA X3x00 series
Jul 05, 2009 | Acer Aspire 3690 Notebook
More Ram for graphics
You can share the RAM for VGA max of 256 only for some motherboards. On BIOS select the AUTO instead of selecting 128MB share memory.
Mar 24, 2009 | Computers & Internet
Need to now cpu in my laptop
This is just a rough guide, as it all depends on the the games your looking to play, but this is about normal to get games running without problems :
MINIMUM SYSTEM REQUIREMENTS:
Microsoft(r) Windows(r) XP Service Pack 2, Vista
• 1.8 GHz processor
• 512 MB RAM
• 8 GB available hard drive space
• 128 MB video RAM or greater, with DirectX 9 Vertex Shader / Pixel Shader 2.0 support
• Sound card, speakers or headphones
• 56.6 Kbps Internet connection required.
RECOMMENDED SYSTEM REQUIREMENTS:
3.0 GHz Intel or equivalent AMD processor or better
• 1 GB RAM or better
• 10 GB available hard drive space
• 256 MB video RAM,
with DirectX 9 Vertex Shader / Pixel Shader 2.0 support (Nvidia 6800 or better)
• Internet connection with Cable/DSL speeds
Note: recommended specifications provide optimal experience for single player and up to 4 player/medium size map multiplayer.
Dec 05, 2008 | Dell Inspiron B130 Notebook
PACKARD BELL SJ51B008 I have just purchased this item (Refurbed) online, it is a gift for my inlaws. I cannot see anywhere on the spec whether it has USB2 connectivity. I have assumed that in this day and...
Per the specs, it appears that this unit is a good buy, But USB's are not listed :
Full specification
Processor Type
AMD TURION 64 X 2 TK57
Processor speed
800
The higher the number of Megahertz (MHZ) the faster the processor should be
Memory Size
2 GB MB
Memory Type
DDR2
Hard Drive Capacity
120 GB
The bigger the capacity the more you can store
Optical Drives
DVDRW + R9
Screen Size/Type
17"
Graphics Card Type
NVIDIA GEFORCE 7000
To enable images to be displayed on your monitor
Graphics Memory
895 MB
The higher the memory the better quality images you are display
TV-out
NO
Allowing you to plug your laptop into a TV to watch DVDs
Modem Type
Enabling communication with others via the telephone line. A modem is used for the Internet, e-mail and faxing
Wireless Enabled
YES
Allows you to connect to an existing wireless network such as in a office or a wireless hot spot
Other Interfaces
WIFI
Battery Type
LI ION
Software Titles Included
Norton Int Security
Weight
3.5 kg
This is the weight of the appliance in KG
Height
38 mm
Width
393 mm
Depth
275 mm
Colour
BLACK
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Packard Bell Computers & Internet
Laptop
here are some details below find the right one and take it
Model No: TM 2403NWXCi
Platform: Intel Celeron-M Processor 370 (1.5 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
RAM: 256 MB DDR2 400 RAM
HDD: 40 GB
Optical Drive: DVD-Rom/CD-RW Combo Drive
Display: 14.1" Wide Screen XGA TFT w/1280 x 800 resolution
Graphics: Intel GMA900
Other Features: Ethernet / Integrated 802.11b/g Wireless LAN/ 56K Fax-Modem/ 3 USB Ports
Weight: 2.38 KG
Battery: 6-Cell Lithium Ion Battery
O.S.: Linux
Warranty: 1-Year Global Warranty
Price: Rs. 27,999*
Model No: TM 2424NWXCi
Platform: Intel Celeron-M Processor 380 (1.6 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
HDD: 40 GB
Weight: 2.35 KG
O.S. : Linux
Price: Rs. 28,499*
Model No: Aspire 5002NWLMi
Platform: AMD Turion 64 ML-30 (1.6GHz)
RAM: 256 MB DDR333 RAM
HDD: 60 GB
Optical Drive: DVD-Dual Double Layer drive
Display: 15.4" WXGA Acer CrystalBrite TFT Screen w/1280 x 800 resolution
Graphics: N.A.
Other Features: 10/100 Ethernet, 56K Modem, Integrated 802.11 b/g WLAN with Acer SignalUp, Integrated Bluetooth
Weight: 2.9 KG
Battery: 8-Cell Lithium Ion Battery
O.S. : Linux
Price: Rs. 37,999*
Model No: Aspire 5004NWLMi
Platform: AMD Turion 64 ML-34 (1.8GHz)
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 38,499*
Apr 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
56 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
