Question about Panasonic DVDS1 Progressive Scan DVD Player DVD-S1
Dvd s1 err h03 - Panasonic DVDS1 Progressive Scan DVD Player DVD-S1
4 Suggested Answers
SOURCE: panasonic DVD ls 850 , H03 Code error
I was told by a close friend(Authorized Repair Centre) that,the reason Panasonic
discontinued the LS82 and came out with LS86 is because of the Head Rest Mount. The DVD was spinning in Vertical Mode instead of Horizontal.And the bumps it took,while attached to the seat was too much for the Laser assembly.
LS86 is a replica of LS82 just black in color. It Uses the Battery CGR-H712 same like LS 82. Power consumption on both is 22 watts.Yet they claim its 13 hrs. Thats bunch of BS. I have both ,which I bench tested with same settings. And it lasted between 8.5 to 8.75 hrs.Towards the end it was struggling.
Posted on Aug 01, 2008
  • 98 Answers
SOURCE: panasonic DVD ls 850 H03 code error
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Posted on Oct 21, 2008
CPU solution
  • 164 Answers
SOURCE: portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Posted on Dec 18, 2009
What does error H03 means af the Philips portable dvd PD9030?
Go to this link http://tech.rickumali.com/blog/2008/12/30/fixing-my-portable-dvds-h03-error
Aug 06, 2016 | Philips PD9030 9" LCD Portable DVD Player...
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Portable dvd player h03 what to do fix it?
Dec 18, 2009 | Panasonic DVD-LS50 Portable DVD Player
Fuji s1, when I power up I get "Err" message on top LCD screen. Batteries are all freshly new.
"Err" message relates to the batteries.
If constantly lit, It's the AA batteries. When flashing, it's the lithium batteries. It can also be the tiny switch in the media door. Try activating it gently with a pointy object to see if the message disappears.
Dec 05, 2009 | Fuji FinePix S1 Pro Digital Camera
H03 Error & Disc Tray Error
Most likely the tray for your player came out of aligment, this happens when someone pushes on the tray to close it, instead of using the "Open/Close" button, you need to take it to somebody to realign the disc tray.
Jun 13, 2008 | Panasonic DVD-RP56 DVD Player
Panasonic DVD ls 850 H03 Code error, how to solve this problem
Jun 02, 2008 | Panasonic DVD-LS850
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
Mar 19, 2008 | Panasonic DVD-LS90 Portable DVD Player
Error H03
I have had this problem for 2 years, mech.is hanging up. mine was replaced.... 3 weeks later same problem. I take out the disc and very GENTLY press one direction or the other to free it up. works great for a whole movie or several movies in a row. A small amount of electronic lube helps, just make sure you don't get it near the laser head or it will mess things up. Just clean it off real well if you get some on it.
Jan 06, 2006 | Panasonic DVD-LS55 Portable DVD Player...
Panasonic DVDS1 Progressive Scan DVD Player DVD-S1 Logo
144 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
