Question about Miele DA 249-4 Kitchen Hood
Switches on DA249-4 have pushed back due to plastic holder failure, have a new plastic switch retainer to install but unable to work out how to get to the rear of the switch assy to replace it.
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Remove the flue cover
Posted on May 06, 2017
Rear vent controls not working
The rear blower motor switch and the rear floor console switch bezel are serviced only as an assembly.
  1. Disconnect and isolate the negative battery cable.
  2. Remove the rear floor console.
Rear Blower Motor Switch
  1. Remove the rear floor console switch bezel by releasing the retaining tab located at each end of the switch bezel and pushing it out through the front surface of the console.
  2. Disconnect the wire harness connectors from the rear blower motor switch and the rear heated seat switches.
  3. Remove the rear heated seat switches from the rear floor console switch bezel by gently prying the switches free from the back of the switch bezel.
  1. Install the rear heated seat switches into the back of the rear floor console switch bezel. Make sure that the switch retaining tabs are fully engaged to the bezel.
  2. Connect the wire harness connectors to the rear blower motor switch and the rear heated seat switches.
  3. Install the rear floor console switch bezel into the rear floor console by pushing it in through the front surface of the console. Make sure that the bezel retaining tabs are fully engaged to the console.
  4. Install the rear floor console.
  5. Reconnect the negative battery cable.
Feb 20, 2014 | Chrysler Pacifica Cars & Trucks
I'm trying to change my brake light switch on my 1995 gmc Yukon. I can't figure out how to take the clip off that hold the switch on
Most GM brake light switches are held in the hole by a steel clip that grabs on the plastic threads. To remove the switch, you just grab the switch and pull it out. Requires a little effort. When you replace the switch, it pushes back into the clip fairly easily as the clip has one way tabs. You push the switch in until it bottoms out on the brake pedal arm. The threads are just there for the clip to grab onto. In rare cases where the clip fails to retain the switch, I have had to screw a nut onto the back side of the switch to prevent it from backing out of the clip. This is the case sometimes when you are reinstalling the same clip. Otherwise a new one will generally hold because of the new plastic threads.
Dec 12, 2012 | Cars & Trucks
How do you replace the bulb behnd the cluste on a 1994 Honda Acord, I removed the two top screws and the AC knobs, does the radion and console have to come out as well?
yes, the radio has to come out, as 2 of the trim panel screws are hidden by the radio.
1990-95 Accord
See Figures 7, 8 and 9
  1. Disconnect the negative battery cable. If so equipped, disable the Supplemental Restraint System (SRS).
  2. Lower the steering wheel to its lowest position.
  3. Remove the center console.
  4. Remove the ashtray and ashtray holder.
  5. Remove the radio/tape player.
  1. Remove the coin box, switches and dash light controller from the instrument panel.
  2. Remove the mounting screws securing the instrument panel. This is a large, formed piece of plastic-don't crack it.
Fig. Fig. 8: Instrument panel retaining screw locations on 1994-95 Accords
  1. Lay a protective piece of cloth over the steering wheel pad.
  2. Remove the four screws holding the instrument cluster. Pull the cluster forward enough to allow access to the wiring connectors.
Fig. Fig. 9: The instrument cluster is retained by four screws
  1. Disconnect the wiring harnesses and remove the instrument cluster.
  2. Individual instruments may be removed from the cluster after it is removed from the car. Avoid damage to any terminals or the printed circuit board.
To install:
  1. Install the gauge cluster; connect the wiring before it is fully in place. Install the retaining screws.
  2. Install the instrument panel. Make sure it is correctly placed. Install the retaining screws.
  3. If applicable, install the air vents.
  4. Install the coin box, switches and dash light controller.
  5. Install the radio, ashtray holder and ashtray.
  6. Install the console.
  7. If applicable, enable the SRS.
  8. Connect the negative battery cable.
Nov 30, 2011 | 1994 Honda Accord
What type of fitting attaches engine oil cooler lines to left side of radiator on 1995 g20 full size chevy van
push connect fitting to take appart back up plastic retainer ring (looks like flat washer)
then ther is a nap wire clip that you can push in to release locking tabs if to dirty pull it
straight out (pick hook works fine or pliers if you cn reach
then pull line will twisting back and forth untill free
new line should come with new retainer washer and wire clip
installed wire clip first then push line on until it looks in installed retainer
start motor and check for leaks
Apr 02, 2011 | 1995 Chevrolet G20
Electric window motor doesn''t work needs replacement
Remove the visible bolt from the left side of the arm rest.
Remove the window switch/door lock/mirror controls by popping the entire panel out, may need to use a flathead screwdriver.
Slide panel off of door.
Pull vapor barrier loose on the bottom right side. This will expose a coiled spring and window motor. Tape the window in the up position using masking or packaging tape.
Mark a straight line across the coil spring, to help with realigning the new motor.
Use tool j-38864 connect it near outer part of coil sprint where it hooks to retainer or in a pinch use pounted vice grips at same location ensuring they are firmly locked on spring.
Force spring clockwise to disengage it from it's retainer point.
Pull spring slightly outward just enough to clear the retainer point and slowly let it uncoil counterclockwise.
Disconnect wire connector from right end of window motor.
Push the three plastic retainer points outward as you lift up on window motor to disengage from retainers careful not to break the plastic retainers comes out pretty easy
Install new motor into the plastic retainers, make sure it is fully seated.
Reconnect wire connector to new motor.
Use J38864 or vice grips to recoil spring, reseating it to retainer point as before.
Remove tape from window and test up/down switch.
Reseal vapor barrier in place as it was before.
Slide switch control back up through hole in door panel from where it mounts and slide door over the door handle.
Align retaining clips to holes and push them home with gentle raps of your hand start at the top and work downward on panel.
Replace the bolts in the arm rest and pop back in the controls.
Mar 04, 2011 | 2000 Pontiac Montana
How do you remove the inside door panel backseat right side of a mercury grand marque 1996
Door Panels REMOVAL & INSTALLATION 1989–91 Vehicles
  2. On 1990–91 vehicles, remove the speaker grille.
  3. Remove the retaining screws from the door inside handle cup.
  4. If equipped with armrest courtesy lamps, remove the lens, detach the bulb and wiring assembly from the pull cup and remove the pull cup.
  5. Working through the pull cup opening, disconnect the remote lock rod from the lock knob.
  6. Remove the retaining screw and the remote mirror bezel nut from the power window regulator housing switch plate, if equipped.
  7. Raise the plate to expose the window switch and power door lock switch and disconnect the switches.
  8. Remove the retaining screws from the armrest finish panel.
  9. Remove the retaining screws from the armrest and remove the armrest.
  10. Using a suitable trim pad removal tool, carefully pry the trim panel plastic push pin retainers from the door inner panel. NOTE: Do not use the trim panel to pry the clips from the door inner panel. Replace any bent, damaged or missing push pins.
  11. Disconnect the radio speaker wiring, if equipped.
  12. Remove the trim panel and watershield. To install:
  13. If the door panel is to be replaced, transfer the plastic push pins to the new panel. Make sure that the watershield is positioned correctly to the door sheet metal. Remove the door pull handle from the old panel and transfer to the new one.
  14. Position the door panel loosely to the door belt opening and route the wiring harness through the appropriate access holes in the panel.
  15. Connect the radio speaker, if equipped.
  16. Align the plastic push pins on the door panel to the holes in the door sheet metal and press the pins into place.
  17. Install the armrest and route the window regulator, remote mirror cable and power lock harness through the access hole.
  18. Install the armrest finish panel.
  19. Install the power window regulator switch plate housing to the armrest connecting the power window switch, power door lock switch and remote mirror bezel nut, if equipped, prior to securing the retainer screw.
  20. Connect the lock remote rod to the lock knob retainer boss. NOTE: Make sure that the remote rod is fully seated into the retainer boss, then function manually or with the power switch to ensure smooth operation of the lock knob.
  21. Install the bulb and wiring assembly.
  22. Install the lamp lens, if equipped, and the pull cup.
  23. On 1990–91 vehicles, install the speaker grille.
  24. Connect the negative battery cable. Fig. 1: Front door panel — 1990–91 vehicles 84170064.gif
    Fig. 2: Rear door panel — 1989–91 vehicles 84170065.gif
1992–98 Vehicles
  2. If removing the driver's door panel, remove the nut from the outside rearview mirror control switch.
  3. Remove the window regulator switch housing by gently prying up, starting at the front. Fig. 3: Front door panel — 1992–98 vehicles 84170066.gif
    Fig. 4: Rear door panel — 1992–98 vehicles 84170067.gif
    Fig. 5: Remove the window regulator switch housing by gently prying up, starting at the front 89600p08.jpg
  4. Detach all connectors from the switch housing.
  5. Remove the door inside handle cup.
  6. Remove the push pin from the door trim panel upper front extension and remove the screw.
  7. Remove the lower self-tapping screw retaining the door trim panel to the door inner panel. Fig. 6: Detach the switch housing electrical connector and remove the housing 89600p09.jpg
    Fig. 7: Remove the door inside handle cup 89600p01.jpg
    Fig. 8: Remove the screws from the door panel in the front and on the upper extension 89600p02.jpg
  8. On Grand Marquis, pry up the screw covers from the door pull handle and remove the screws and handle.
  9. Lift the door panel upward and snap out the panel. Fig. 9: There are also retaining screws located in the map pocket as well as . . . 89600p03.jpg
    Fig. 10: . . . along the bottom edge of the door panel 89600p04.jpg
  10. Disconnect the necessary wire harnesses and remove the panel. To install:
  11. Connect the wire harnesses to the door panel, as necessary.
  12. Install the door panel by pushing in and down until it snaps into place.
  13. Install all self-tapping screws retaining the door trim panel to the door inner panel.
  14. On Grand Marquis, install the door pull handle, tighten the screws and install the screw covers.
  15. Install the push pin covering screw on the panel upper front extension.
  16. Install the inside door handle cup.
  17. Install the window regulator switch housing and install the nut on the outside rearview mirror control switch, if removed.
  18. Connect the negative battery cable. Fig. 11: Lift the door panel upward and snap out the panel to remove it from the door 89600p05.jpg
    Fig. 12: Rotate the door marker lamp bulb and remove it from the door panel 89600p06.jpg
    Fig. 13: Detach the connectors for the trunklid and fuel door release switches 89600p11.jpg
    Fig. 14: Slide the relay connector off of the door panel and remove the door panel from the vehicle 89600p17.jpg
Aug 26, 2010 | Mercury Grand Marquis Cars & Trucks
I am troubleshooting the driver's side power window controller. Driver's window does not move up/down. Seems to be a problem inside the controller on door panel. Need help taking the controller apart,...
Ive installed alot of after market stereo equipment in these types of vehicles, usually to get to the switches you have to remove the door panel, and unscrew the two retaining screws that hold the switches in place, disconnect the wire bundle from the switches, press the retaining tabs on the side of each switch and push them out of the holder. As far as the cover that covers the switches it usually just pops off as it is being held in place with a positive retention spring tab. Before attemping to push out make sure there arent any retaining screws that hold the switch cover in place. Hope this helps.
Aug 07, 2010 | 2000 Chevrolet Suburban
Where is the turn signal signal flasher located in a 2001 New Beetle?
The emergency flaser switch IS the turn flasher relay, too! Getting access isn't easy. You need one of those fancy-smancy star-shaped screwdrivers (and a stubby, at that) to remove the 4 screws... two at the bottom of the plastic housing in which the switches are mounted, and two more are revealed whenever you pry off the plastic trim that surrounds the rheostats at each end of the switch panel (yep, they just pry right off with your fingers... pull TOWARD you).
Once you have the 4 retaining screws extracted, you can pry the whole switch panel downward at the back, and free up a lip on the upper front edge, dropping the whole thing downward so you can access the wiring harnesses and back-sides of the switches. Pry off the wiring connector from the back of the unit (there's a plastic keeper, but just wiggle the plug & pull sternly and it'll come right off without breaking anything). Then push down on a retainer at the top front of the switch unit and shove it forward and slide it out of the switch panel.
Good luck (remember rated this).
Aug 04, 2010 | 2001 Volkswagen Beetle
My peugeot 307 gear linkage counter balance
i can't change into 2nd,4th and reverse gears. i think its a gear lever cable not sure doe any ideas?
Dec 27, 2009 | 2005 Peugeot 405
Need to remove door interior panel on driver side of a 1989 Lincoln Mk VII to be able to repair the window open mechanism.
Door Panel
  1. Remove the retaining screws from the armrest assembly.
  2. Remove the screws retaining the switches to the housing and remove the cover assembly.
  3. Remove the door trim panel retaining screws.
  4. Using the trim pad removing tool, pry the trim panel retaining clips from the door inner panel.
  5. Disconnect all the wiring, if so equipped, and remove the trim panel.
To install:
  1. Position the trim panel to the door inner panel and connect the wiring, if so equipped.
  2. Push the trim panel and retaining clips into the inner door panel holes and install the retaining screws. Install the screws retaining the switches to the housing.
  3. Position the armrest to the trim panel, and install the retaining screws.
Dec 07, 2009 | 1989 Lincoln Mark VII
Miele DA 249-4 Kitchen Hood Logo
100 people viewed this question
Top Miele Kitchen Ranges Experts
Jim Thurston
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
