Question about D-Link DI 514 Wireless Router (DI-514)
Set Secutiry on Router http://192.168.0 - D-Link DI 514 Wireless Router (DI-514)
    President:
  • 662 Answers
Set security on router with IP address http://192.168.0.0, not
http://192.168.0. you'll also need to know the password to enter
the router's configuration/management page - check you manual - the default password will be there.
Posted on Oct 13, 2010
2 Suggested Answers
eastpole
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
I am trying to set up my wireless internet to my PS3. What do I choose WEP or WPA - PSK under WLan secutiry and how do I know the codes?
Wireless internet is provided with a wireless router. The router will be what you set up for the WEP or WPA codes.
Jan 02, 2011 | Arris SURFboard SB5101 Cable Modem
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
RouFlashing ADSL light
have yo properly configure the setting imean dsl account ,dns setting etc of belkin
Aug 15, 2009 | Computers & Internet
Password setup problems
ok this is simple but at the same time kinda confusing open an internet window and type in 192.168.1.1 the password on defalt is going to be eather password or admin and the username is admin after you get past the login it should take you to a setup page click on wireless at the top  after you click on wireless just under that click wireless security thats the settings to change the wireless security in there you can chose what type of secutiry you want i normaly use wap2 on TKIP after setting those type the password you want after that save it and close the window on all the computers that use wireless your going to have to disconnect them and reconnect them from the network it will ask for the password enter it and make sure it saves the password and your set if you have any problems in the process let me know if be glad to help
Please rate this
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
How do I get to the encription part of my belin as I keep entering the code and it will not allow me in
take a ethernet cable then connect to you router in lan port then other end connect to pc the go to the internet explorer in the address bar type the default ip address of your router then username and password give it as default then go to wrieless option in that sectiury is there then go change your secutiry
Mar 20, 2009 | Belkin (F5D7230-4) Router (587009)
Secutiry issue
You will need to access your router and configure your wireless settings. If you are uncertain about the password/username to access the router 0 then you might find it on label at the backside of the router.
Failing this - the favourite combinations are :
Username admin
Password admin
or sustitute "password" (without the quotes) as the password. If that does not work then you could "google" the question.
Feb 20, 2009 | Zyxel Prestige 600WH Wireless Router...
Secutiry for BelkinF5D7230-4 router using Vista
Hi, here's a quick guide for you:
1. Connect to the router via Ethernet cable
2. Login to the router via a web browser, by typing 192.168.2.1 in the address bar
3. Click to login, leaving password blank (unless you have set a password)
4. Go to Wireless > Security. Select Security Mode WPA-PSK.
Enter your network key (password) under ‘Pre-shared key’ – make a note of it – click ‘Apply Changes’. That’s it, your wireless is encrypted.
For better security/more details:
1. Pick up a manual from Belkin UK
2. When you’re in your user interface, change the SSID and router password for a better level of security (see this tip for more details).
Hope this helps, but please come back to Fixya if anything doesn't work, or if you need more info. Good luck
Jan 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Having problems with the security key/passphrase
u will be able to find the secutiry key at the back of ur modem or at the router page. let me know the router name if unable to find the wireless key still
Nov 12, 2008 | Netopia 3-D Reach (TER/GUSB-N1)...
I cant remember the password i entered to protect my wireless from others. is there a way i can retrieve this password without using the disc
Hook up to the router over ethernet
Browse to 192.168.2.1 (Assuming you havent changed Ip Address)
Click Secutiry in the left menu.
Enter Username and Password if required, click submit.
Youll now be able to see your WEP or WPA key
Heres a link to the wireless setup guide
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D8231uk4&aid=10065&scid=282
Regards
Nick
Oct 28, 2008 | Belkin (F5D8231-4) Wireless Router...
D-Link DI 514 Wireless Router (DI-514) Logo
4,393 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
