Question about Technics SL-PD687 5-Disc CD Changer
Distorted sound when playing CD
Over time, I got intermittent distortion of sound on the CD player. Eventually, it was distorted all of the time. Sort of "jumpy" and "slippery". Everything else on the boombox works fine. The same audio CDs sound fine on other CD players.
  • 3 more comments
  • LehuaPahoa May 31, 2008
    I have cleaned it again and again, and have tried different brands, just to be sure. It didn't help.
  • LehuaPahoa Jun 01, 2008
    What is the optical connection and what do I need to do to use it?
  • benzsty Sep 14, 2008
    I have a Sony cd Player. I cleaned the lens and even adjusted the laser. The disc spin it plays and then all I hear is distortion.
  • twinspin2 Dec 30, 2008
    I have had the same problem too. I see that the laser pickup mechanism is available as a replacement part for about £40. Trouble is I cannot seem to disassemble the two parts of the mechanism. There must be a trick or something that is not obvious.
  • Anonymous Feb 07, 2009
    The only time i have sound is when I play cd's and it is distorted. I can still make out the song some what.
  • 3 Answers
I had exactly the same problem and ordered a new laser pickup costing about £40.00. A bit of a gamble and a little fiddly until you know how to do it. I also purchased a service manual to help me disassemble the mechanism. I am an electronics/radio engineer so I managed to do the job successfully but wouldn't recommend it to the average handyman without temperature controlled soldering iron desoldering pump and suitable tools including wriststrap and antistatic mat. The player now sounds better than it did ever with clear and brilliant audio. Total cost about £50.00 but worth it for me. If anyone feels that they can tackle this repair I can give further details on separating the servo board from the laser assembly.
Posted on Jan 08, 2009
I have 2 of the CDP-CX400 machines that do the same as you are describing. The only solution I was able to discover, with amazing results, was to use the optical connection. The sound is far superior. My challenge now is trying to get the crossfade between the two players to work via optical.
Good Luck!
Scott
Posted on Jun 01, 2008
  • 158 Answers
Have you tried cleaning the cd lens ?insert a lens cleaning cd , follow the voice instructions and your cd player will be as good as new.HAPPY LISTENING.
Posted on May 31, 2008
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
May 04, 2014 | 2002 Acura 3.2TL
Philips Electronics 46PFL3908 46 sound distortion
sounds like you burnt up the amp chip only way to fix is to replace thw whole circuit board
Mar 24, 2014 | Philips Electronics 46PFL3908 46" 1080p...
Distorts the sound when reading most of the time.
The Op Amp in the unit are oscillating if you hear hiss and if there is distortion they could be bad. This is a job for a Technician to check out.
Make sure you are NOT plugging in a CD player output into a Phone input on a receiver or amp. The CD is 1000 time too much voltage.
Dec 14, 2012 | Sony CDP-CE275 5-Disc CD Changer
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have logitech x220 speaker set up, but I am getting intermittent distortion. Which renders them useless for playing music, they even distort computer warning noises! I have changed from an integral sound...
actually the harddrive could also be the problem, because when you do have a problem with your HDD your computer tend to intermittently hangup or freezes that causes the distort effect on the sound system. Also you could try using your speaker on a different computer or plug it on an mp3 player so that you could eliminate the factor that your speaker has the problem and if not try using another HDD for your computer or worst case scenarion would be changing the motherboard of your computer.
Jun 01, 2010 | Computers & Internet
Denon DNS1000 distorted/fuzzy sound
Please visit www.denoindjforums for further help.
Jan 31, 2009 | Denon Dns1000 Table Top CD Player CD...
Get bad sound quality after playing a few cd's.
Try Googling (american audio)(MCD 810)(manual) without parens.
Aug 03, 2017 | American Audio Mcd810 Dual Mp3 CD Player...
Player 2 skips and plays a different track
May need manual cleaning or Cd Mechanical assembly may need to be replaced
Dec 03, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
DVR 120 Disc/Screen freezes half way through
CD does not run
Clean lens and adjust the disk level
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
This fault would only occur on c.d play back. The sound would gradually start to distort, until all that could be heard was complete distortion. This fault was intermittent and would occur whenever it felt like
Believe it or not,this fault was cured by replacing the optical unit
Nov 24, 2007 | Samsung DVDR120 DVD Recorder
Technics SL-PD687 5-Disc CD Changer Logo
404 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
