Question about Frigidaire PLMV169DC Microwave Oven
The microwave doesn't seem to be bringing the air up into the vent for exhaustion outside. It's brand new.
    Scholar:
  • 30 Answers
I presume that you can hear the fan running? If so, most over the cook top microwaves have an option to vent to the outside or simply recycle through the filter and vents above the unit. If you check your manual there should be instructions on how to change this configuration to suit your situation, but it likely needs to be done before you install the microwave.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137234.pdf
The above manual shows how to reconfigure the microwave from recirculation (as shipped) to external exhaust setup on pages 4 - 5.
Posted on Oct 21, 2010
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
Vent fan filter??cleaning,etc does not seem to pull air out as it runs
If this is a new installation, or if this ove is new to you, the following may apply: on some ovens the vent fan can be flipped to either exhaust air out of the house, or re-circulate it. Could it be in the wrong position? You would have to take the oven down to determine this.
May 25, 2014 | GE JVM1653 Microwave Oven
Emerson microwave mwg9115sl over heats then turns back on after 20 minutes
Your magnetron is overheating, which can be caused by:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
The first suspects in my book are fan failure, blocked vents, or bad magnetron.
Jan 10, 2013 | Emerson Microwave Ovens
The exhaust system never has worked. Will not pull any air from the cooking stove under micro as it was supposed to.
Check the cabinet over the top of the microwave, the unit should be vented to the outside of your home, if not it was a venting model and just never connected to the vents.
Jun 14, 2010 | Maytag MMV4205 Microwave Oven
I had the exhaust switched from inside to outside venting, but there is no air intake. What do I need to check?
Check to see if the damper is stuck, either on the exterior vent outside the house or at the microwave. Also, did the blower get turned to point at the desired exaust direction. Unfortunately, both interior possibilities will require removing the microwave.
Dec 27, 2009 | Microwave Ovens
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
Oven is installed not outside vented. There is
It could be that the filter elements are clogged and need to be cleaned. Remove then from the underside of the micro hood and clean them using a good quality cleaner, such as Simple Green. Clean and allow to air dry before reinstalling.
While the filter elements are out, you can check for obstructions and run the fan to see if it is better without the filters installed.
If there is no noticeable increase in the air flow, it is possible that the exhaust vent baffle was not installed correctly, when the mircrowave was first installed.
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | GE Advantium 120 Convection/Microwave Oven
Exhaust fan doesn't work and blows air from top vent
Some microwaves have a adjustable fan. We have one that you can vent out the back, the back top or through the front top filters. The latter is what it sounds like you have. If you take the small back panel off and lift out the fan motor you'll see that you can place it in the direction you like.\\
KK
Jul 04, 2009 | Kenmore 60654 Microwave Oven
Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
256 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
