Sony CDX-M8800 CD Player Logo
Posted on May 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony CDX-M8800 face plate is non responsive
I have a sony CDX-M8800 installed into a 92' volvo 960. the installation was done by best buy when the model first came out. now the face plate is not responindg. the actual unit shows power but the face plate doesnt work. if you know how i might go fixing it let me know. thank you
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
996
Points
Sony CDX M8800 NOT RESPONSSIVE:
I WAS FAST FORWARDING A MIT-TAPE CD AND SUDDENLY, THE HEAD UNIT FROZE[NOT RESPONDING TO REMOTE CONTROL AND BUTTONS] BUT CONTINUED PLAYING THE CD.
I MANAGED 2 ENJECT THE CD AND CHOSE TO "RESET" THE UNIT[CXD M8800]
UNFORTUNATELY, THIS MADE IT WORSE AS THE UNIT SINCE THEN,NON RESPONSSIVE.EVENT AFTER DISCONNECTING AND RECONNECTING ITS POWER CABLES.
PLEASE HELP: WIL BE VERY GRATEFUL
THANX
DANEH
Anonymous
Level 2:
  • Expert 59 Answers
  • Posted on May 30, 2008
Anonymous
Expert
Level 2:
Answers
59
Questions
0
Helped
33979
Points
124
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
5helpful
Buttons on my sony CDX-GT540UI stopped working
Sony car radio cdxgt540ui buttons non responsive - remove four screws on reverse side of faceplate, pry open with fingernails starting at the top right or left corner of the face plate once opened remove board on the reverse side of the LCD there are small brackets holding the LCD use a needle nose to pry each bracket in straight position then remove LCD for ten seconds then place back on to board and been brackets back in place. After these steps the front buttons should work again this process worked for me.
1helpful
Need the radio code for my Sony CDX-M8800 CD/Car radio to turn it on, I do not have the remote.
There is no code for this radio. Chances are it probably has a bad flexible cable that goes from the face to the main motherboard.
Im trying to install my sony m8800 in the house with a pc power supply can you tell me which wire goes where many thanks
Hi:) If you want the install file for the CDX-M8800 send me a email and i will send it with return email.
[email protected]
1helpful
Need a wiring diagram to install cd player
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address2_bing.gif.
Here you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
2helpful
2answers
Need security code for my sony cdx-m8800
Sony CDXM8800 Radio Codes are available from the website - www.instant-radio-code.co.uk
Faceplate will not open
Perhaps something is not installed correctly physically. Sometimes if something is a little twisted the way the unit is installed it will keep it from opening properly. Try moving the unit slightly and see if that helps.
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
