Question about SanDisk Sansa e260 MP3 Player
Rebooting and rebooting and rebooting
I've tried everything that anyone has said and all it does it reboot and reboot and reboot...help?
  • 8,596 Answers
Hardware issue then - this player must be replaced. Make sure you have tried all of these methods first:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 07, 2008
Battery light on nothing else
Has there been ANY damage? Have you tried another Cord/Charger with the EXACT same power specs? Has the AC jack been damaged due to pulling on the cord while plugged it? Unplug, remove battery, plug in, try to reboot. Has it been overheating? Fan, vents, heatsink clean?
May 06, 2013 | IBM Lenovo ThinkPad T400 Notebook
Obd2 code p0562
Low battery charge, Battery Defective(Could have a bad cell), Loose or missing alternator drive belt, Faulty Alternator, Open or short system voltage circuit
Apr 11, 2017 | Mazda RX8 Cars & Trucks
OBD2 CODE READER P0562
fully charge battery and make sure everything switched off i.e rear window demist etc and take it for a run to get it up to tempature then park up rev engine at fast idle approx 2750 rpm for 180 seconds then take foot off throttle and allow to idle for 30 seconds this will clear your catalyst and get it up to the 600 degrees needed for it to operate properly this should remove the engine warning light
Apr 21, 2013 | Mazda RX8 Cars & Trucks
Make sure your 12V grounds to engine and chassis are good.
After installing windows 7 my cd drive doesn't work. I've tried new drivers and disabling it and everything else I can think of... can anyone help?
Are you sure that you have installed the correct driver? Try going to the website of your computer's manufacturer and get the driver from there.
David
Mar 26, 2013 | Dell Inspiron 1525 Notebook
I WANT TO REBOOT MY NETBOOK
Reboot the computer and as soon as it turns on start tapping F9 repeatedly. Do this immediatly after hitting the power button. If Windows Starts to load - you will need to reboot and retry.
Hitting F9 should take you to the recovery partition option. If you select to run it - it will erase everything on your laptop and set it back to factory defaults.
If you have more questions, consult the manual that you can download here: http://support.asus.com/download.aspx?SLanguage=en&p=20&s=1&m=Eee%20PC%20R101&os=17&hashedid=GhBUCjHj4BRr7ndV
Hope that helps!
Nov 21, 2011 | Computers & Internet
Hey.. I've got GT S3310 and I use the code *#6984125*# > Internals *#9072641*# to update my java database when installing games. I was kinda exploring the Admin Settings when I accidentally clicked...
it seems the firmware of your cellular phone got corrupted, you have to reinstall them. dont bothered you can update them through PC suit or can take help of professional.
vote me if found helpful.
Aug 05, 2011 | Cell Phones
SanDisk Sansa e260 MP3 Player Logo
53 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
