Question about Behringer EUROPOWER EP2500 Amplifier
I have an EP2500 that is intermittent as far as both channels working at the same time. It always has at least one channel working, you just never know which one is going to work until you power it up. It is an older amp so I am trying to determine if it will be worth it to ship it somewhere to have it repaired. Does this issue sound like a common problem with this amp? What is the closest repair center to Nashville TN?
    Genius:
  • 1,175 Answers
Being an older amp , I would first dust out the innerds and call the music store you bought it from for a tech that they use.
Sounds like some solder connections have given up
Posted on Oct 10, 2010
My EP2500 keeps on blowing a fuse on the right channel and I opened it and realised that the two horizontal caps are a bit bigger.
They wouldn't blow the fuse. You are looking at the main devices that power the channel. If you put an ohmmeter on their terminals (assuming they are transistors) then it will show like you have touched the two test probes together. If it does replace the part(s).
Oct 24, 2013 | Behringer EUROPOWER EP2500 Amplifier
What number on each channel on behringer ep2500 to set for behringer vp1220 speakers
It is best to start with the mark on the ep2500 directly up (12 o'clock position). Gradually increase the output on your mixing board (MAIN MIX) to get desired volume. I you find that you're getting close to -10 to 0 dB, then start increasing the volume knobs on the ep2500. Watch for clipping on the amp.
Oct 11, 2012 | Behringer Ep2500
I have EP2500 amp i want to use it to push 6 tops, what should i switch it to? one channel must push 3 tops and the other as well pushing 3 tops.
OK, you can use ep2500 amp to power 3 tops each,But the only challenge is that you are about to over load your amplifier. might get hot too fast .
You can use a cooling system to make it not too hot..It also depends on how the event your using it for...Using 3 EP2500 amplifier to drive three 6 top, using two top for each amplifier. Just a suggestion.
Using 2 amplifier, you will need to drive on one channel to drive 2 tops, and 1 top for the other channel.
That will do. But make sure you turn on the volume of the amplifier to the max volume ,so that it will be able to work properly for your tops...
Mar 31, 2011 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 Clip light Channel 2 stays on & heatsink HOT!
There are so many components that can fail that troubleshooting this can be an expensive problem.
HINT: Put a 150 Watt light bulb in series with the power going into to limit current for/during troubleshooting.
Go through and compare the voltages on the teo channels. If power amp transistors have failed, likely the driver transistors also are gone.
Testing components in-circuit is very dificult. Resistors are pretty reliable and usually show damage by discoloration.
Furhter use before repairing MAY cause further damage.
Jun 03, 2010 | Behringer EUROPOWER EP2500 Amplifier
Does anyone has overheat problem with Behrigher EP2500 power amplifier? We had the amp for abut a year. The amp. has recently become overheat (hand burning) after 30 minutes operation. We set the gain to...
The last time I had a problem like this there was a defective transistor in the from end that was generating noise in the 30K range. Too high to hear and too high for the speakers to reproduce, but enough to put quite a load on the amp. Does this occur even with no speakers attached? If so, then put an osciloscope on the outputs and look for signals. WIth no input, there should be no output at all except for a little noise. You can also see if there is any DC on the outputs as well.
Please update this with what you find.
Thanks,
Dan
Oct 13, 2009 | Behringer EUROPOWER EP2500 Amplifier
Two 4-OHM DVC AND two 4-ohm
your amp is stable at 2ohm in stereo mode . you can wire them in series or parallel. series you add up the ohms . parallel you use this (R1+R2)divided by(R1xR2)=total resistance this figures two speakers at a time to add more speakers after total repeat formula as long as you don't go below min load you are fine . in your case all speakers in parallel you would be running 0 ohms bad . in series you would be running 16 ohms stable but not even half the power of your amp. if you hook up two in parallel and two in series on one channel you are running 1.6 ohms still not stable.If i was u I would hook up two 4ohm speakers in parallel on one channel and two in parallel on the other given you a stable 2ohm per channel.
total power output per channel 1200w
Jun 20, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 no output on CHANNEL 1
check all op amps for correct voltage swing +-should be equal,test output of op amps no voltage should be present, use chasis gnd as tester neg.check voltage regulation especially 12v or 15v +-.note some amps show unequal led indications when only 1 channel connected to a load.I will try to get some more info on this specific amp because i don't know this circuit well,keep in touch as you update though.
Aug 21, 2007 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
