I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing cycle to begin, the machine stops. the rpm light indicates 0. when i select spin, it drains when i put it on that cycle but it just wont wash? 2 kids and lots of dirty clothes please help
  • manweek Oct 14, 2010
    ended up contacting repair agency. they think it might cost up to $500 to fix washer after ordering parts and having to return in a few weeks to fit part
    looking for new washer. 6 loads at home waiting to go
  • manweek Oct 17, 2010
    we ended up getting a new whirlpool wfs1073cd front loader. same problem
    it wont complete the wash cycle
    connected it up, turned it on, start the cycle, water comes in, starts to spin and after 5 mins or so stops. spins and drains ok. no problems with hoses, water pressure or outlets
    calling tech on monday
    tks
    dave
    Genius:
  • 1,416 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches (a technician tools)to replace the panel on the washer and push it back against the wall
  • Thank and thanks for visiting fixya.
    Posted on Oct 10, 2010
    • Oloyede Monsuru Oct 17, 2010
      hello,
      Since the whirlpool wfs1073cd front loader is still new of just bfrom the store before you can start opening it you will have to consider the warranty or guarantee that cover it from the store/point of purchase. that is contact the seller then pass the complain them
      thanks once again.
    Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
    Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
    To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
    Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool AWM 5080 stops during cycles
    Sound like could be faulty pump however you need to make sure no
    Could be pump at fault 1st you need to make sure no coin stuck in there ...
    Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
    Front loader AWM 6100 - door open light flashes and won't wash
    I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
    Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
    Washing cycle starts and takes hours even for short cycle.
    Try checking for good water supply.
    Pull out detergent tray and check for good water supply during filling.
    if poor filling-
    Try checking the hoses.
    Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
    if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
    Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
    Whirlpool 6th sense front loader awm 8121
    my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
    Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
    Front Loader - whirlpool - does not star
    machine controls may be locked. Power on the unit and hold in the far right button for 4 seconds and then try to select settings and cycles
    Apr 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool AWM 6100 wont let in water?
    this may sound silly but is the hot and cold hoses around the right way
    Feb 18, 2008 | Washing Machines
    Washing Machines Logo
    161 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
