Question about Estate TGDS840JQ Gas Dryer
It has no heat when we turn it on we took it apart and we have no flame
  • 171 Answers
You may need to light the pilot light at the valve going in to the dryer.If you have the owners manual it should tell you how to light it. Be careful it is not a hard thing to do but take caution and follow the steps correctly. If this has helped you don't forget to hit yes in the box and good luck friend!
Posted on Oct 10, 2010
Gas dryer runs but no heat. Took it apart cleaned all ducts and lots of years worth of dirt out of entire machine, looks brand new. Tested all components.
You did quite a bit of work. One other thing that controls the ignitor is called the flame detector. Its the black box looking thing mounted on the side of the big pipe the flame shoots into. Should be 2 wires going to it. A quick test to see if the ignitor comes on is to tie the 2 wires together. If you see the ignitor come on thats the bad part,
Jun 29, 2015 | Dryers
I have a Charmglow electric fireplace that does not heat nor does the blower work. The flame light does turn on and turns. Model # 6901050100 Cat # 409896 It worked then quit. tore it apart, it wo
Did your circuit breaker blow.in your electrical box. Check that first before anything else. Sometimes if you have anything else on the same circut as a heater the breaker will shut down.
Jan 05, 2015 | Heating & Cooling
Why does my dryer start to heat up and then stop heating
check for damage to your burner fan, usually there is a vacuum switch that can cause the same issues, on some units the ignitor is used as a temp sensor, which tend to melt and give false readings.
Dec 19, 2013 | Whirlpool GGQ9800L Gas Dryer
Boiler without flame sensor
Sounds like the hot surface igniter is also a local sensor. If you unplug the molex 2 wire plug of the igniter, and turn your meter to resistance, I found that it should read under 110 Ohms. If it is over that amount, the igniter may not sense the flame. Replace the hot surface igniter.
Dec 03, 2013 | Bryant Heating & Cooling
Whirlpool LG7681XSW2 gas dyer will not stay hot
You have a faulty "flame sensor". Here is the part to order.
The flame sensor is number 49 on this diagram.
To replace the flame sensor, remove the back panel to gain access to it.
The part comes with a 365 day, any part, any reason return policy.
Nov 04, 2012 | Dryers
Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jun 20, 2009 | Hotpoint NVL333EY Electric Dryer
Patio heater tip switch doesn't let gas through
it sounds like what you are describing is a bad pilot saftey device there is a device called a thermacouple when heated it creates a small electric current which lets main valve know its ok to open we have a pilot flame.the thermacouple normally screws onto gas valve it is 2 spade connectors it is a powerpyle system
Nov 23, 2008 | Coleman 5040-751 BackHome Open Flame Patio...
My dryer does not heat up
You should see a flame if gas, glowing wires if electric(Heating element)
Oct 21, 2008 | Kenmore 63942 Dryer
Electric ignition
I want to know more about your business I repair restaurant commercial equiptment please respond maybe I can help
Sep 08, 2008 | DCS RGS-305 Professional Gas Kitchen Range
Heat to start, then no heat..
replace both coils on gas valve ..those are the blacks things with wires attached they are bad for not pulling valve oper=n after warm up
Jul 02, 2008 | Roper RGX4634KQ Gas Dryer
Estate TGDS840JQ Gas Dryer Logo
64 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
