Question about X2Gen MG19MY 19" LCD Monitor
X2gen 19 inch wont turn on.
The power adapter does have a green light. When plugged into the monitor it pulses. When not plugged in it is solid.
My Acer Orbicam that takes picters and vidios stopd working just like that and i dident do enithing rong it just stopd working please can someone help me
Posted on May 30, 2008
Monitor wont come on.green lite on the switching adaptor is off.Is the adaptor bad or monitor bad? How do I get a new adaptor?Model # WDS048120
The lamp on the power supply adapter should be on the minute it is plugged onto the AC outlet without the DC plug connected to the monitor, if it is not on then the AC adapter is bad, you can check the DC voltage with a digital meter. Post back so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | X2Gen MG19MY 19" LCD Monitor
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
I cannot get power to 19
Hi there...
First check your AC Adapter, see if it still lite green. If it not then you need a new AC Adapter. If AC Adapter still lite green, then your back light inverter are busted. It's more likely your inverter are busted... I can repaired for you... for more information @ www.3rd-Rocks.com Thanks, have a nice day!
Jan 20, 2010 | Fuji FP-988D 19" Flat Panel LCD Monitor
X2gen 19 inch monitor wont power on
Had the same problem with mine. First you need a volt meter (radio shack about $15). check the push in connector and make sure it has coming from it.
Place you meter on DCV for DC voltage, Then place one lead in the end of the plug in the hole. (will not fit all the way so will need to hold it there, Put the other lead on the shiny part of the plug. If you get a reading of 12 volts +/- 1 volt your good. Depending on which lead is were you may get a minus reading this is fine as if you switch your leads around it will go positive. you must have the cord plugged into the wall to do this test. You will not get shocked or anything as 12v is not enough to hurt you.
If you have the 12 volts the problem is in the monitor on the male plug or on the board. this takes more to fix and must take the back off the monitor and fix the connection or replace. I did this to mine and it is working right now.
Apr 10, 2009 | X2Gen MG19MY 19" LCD Monitor
Its turns off and on like no pic nothing
Hi...there,
Well, if you got a AC Adapter check to see if it still lite green. If you don't have one....then it is your backlight inverter are busted...
Nov 23, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen 19 inch LCD adapter
this ac adapter has short circuit protection there must be short circuit in main pcb find out by miltimetre check nearst diodes and transistor if short replace it
Oct 18, 2008 | X2Gen MG19MY 19" LCD Monitor
Replacement power plug
Hi...there,
You mean you got a dead power brick (AC Adapter)??? If you so, you can order one @ www.3rd-rocks.com
Apr 28, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen 19 inch LCD Monitor problem
Its the problem of the main display board. Not the SMPS. There will be another board inside. You have to replace the board or If some body may fix if you have spare parts of the board.
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
Will not come on
Hardware problem You need to take it to a shop or send it back to manufacturer.
Aug 28, 2007 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
144 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
