Question about Mongoose Cycling
Periodic clicking in the bottom bracket - Mongoose Cycling
    Genius:
  • 1,788 Answers
You could have a tight link in your chain or need a bottom bracket rebuild. To check the chain, put the bike upside down and turn the pedals slowly and watch for one of the links to lift slightly, if it does just work the links on either side until it loosens up. Hopefully that is what the problem is. Now, if it is the bottom bracket, take it in for service because you have to have special tools to take it apart. Good luck
Posted on Oct 10, 2010
Bearings do not turn smoothly in DA 7900 BB
i hope this link will help:
http://www.parktool.com/blog/repair-help/adjustable-type-bottom-bracket-service
Mar 15, 2013 | Shimano Dura Ace 7900 HollowTech II Bottom...
The pedal makes a clicking noise
If it's a fairly new pedal, I would remove them and try a different set of pedals to make sure that it definitely is the pedal. Assuming the different set doesn't click, then you may have a warranty issue. If the bike is still clicking, you may have to check the crank and bottom bracket next. The tough thing about clicking noises in the bottom bracket area is that there are a lot of parts that can be causing it and you just have to eliminate them one by one.
May 05, 2012 | Shimano PD-A530
Hi I keep getting a clicking noise when i get out of my saddle to apply more power on my Trek ex6 as any one else had the same problem
Sounds like the saddle undercarriage may be loose where it attaches to the seatpost. Either that, or you may be experiencing a problem lower down - actually at the bottom bracket. Is it a sound that repeats itself with approximately every rotation of the pedals? If there is play in the bottom bracket, this could be the source of your sound. Unfortunately, tightening the bottom bracket requires specific tools that normally only a bike shop will have.
Apr 26, 2011 | Trek Fuel EX 6
Getting a clicking sound from the bottom bracket area. I have a Denali Pro. Can I replace the bottom bracket and what size
Yes, of course you can replace the bottom bracket.
First though you will want to make sure that the clicking noise is in-fact coming from the bottom bracket. Even though it sounds like it is coming from that area there are other things that can cause a clicking noise, such as the examples below.
Front derailleur cable end hitting the crank-arm is a common clicking noise.
Pedals can also cause a clicking noise that sounds like its the bottom bracket.
chain rubbing the front derailleur
chain has a kink in it.
The size of your bottom bracket is related to a few factors:
1 - thread pitch (your bike is english)
2 - Bottom bracket width (your bike is 68)
3 - Crank style and brand. This I do not know for your particular bike as you did not provide the year of the bicycle or brand of crank, and they change.
Taking off cranks and removing and installing a bottom bracket requires many bike specialty tools and is probably not the best project if you have never done this before or own the tools. It will be far less expensive to have your local bike shop replace the Bottom Bracket then to do it yourself. Plus they can tell you what size it needs and if the click is even coming from that part or not.
Dec 10, 2010 | Cycling
Front crank sprocket clicking on bycycle, when I pedal the front crank sprocket clicks, it isn't the pedals.
make sure all sprocket bolts are tight.
check chain to make sure you have all rollers between links are there.this can make a clicking noise or skip teeth if one is missing when you pedal.
if you feel clicking in the pedals (even if you think it isnt the pedals),then it could be your bottom bracket bearing gone.
put one pedal towards the floor and stand on it.did it click?then try the other pedal.if you got it to click then your bottom bracket is loose
Sep 13, 2010 | Cycling
First the horn would blow while turning left, the a clicking sound while turning, then no horn still making clicking sound.
what is the model of your vehicle. Sounds most likely to be a hardware problem in the steering column. remove the steering wheel and you should see (depending on the model) a pin and spring in a circular plastic bracket shaped with the column. periodically the bracket or even spring pops out and grinds triggering the horn(works by suppling a ground to the wire) when you turn also allowing you to here the clicking.
Aug 26, 2010 | Ford F-150 Cars & Trucks
Clicking sound when pedal
Dry or bad bearings in either the right pedal or the bottom bracket (shaft between the pedals).
See this article, particularly the paragraph, "Symptoms of a bottom bracket needing overhaul"...
http://en.wikibooks.org/wiki/Bicycles/Maintenance_and_Repair/Bottom_Brackets/Bottom_bracket_overhaul
Jul 17, 2010 | Pacific International Mongoose 26" Men's...
Cant get the pins out of the crank brackets on the bottom of the crank. got the bolts out but there are pins on each side of the bolts. most engines have two more bolts on the outside edge but this one...
The bottom bracket is the dohickey that connects your two crank-arms together, and secures them within the bottom of the bike frame. The bottom bracket has threads around the outside that secure it into the hole in the frame. Inside, bearings surround a rotating spindle -- this lets the pedals turn free from the frame. Each side of the spindle has a mechanism to connect your crank. This may be square tapered bolts, a toothed ring (splined bottom bracket), or even a threaded bolt. The bottom bracket type must match the crank type (a crank with a square hole must be mounted on a BB with the square receiver).
Bottom brackets also come in different widths, and with different spindle widths: the bracket width should match the frame, and the spindle width should put the cranks out away from the frame, and allow the front derailleur to transfer the chain onto the smallest ring without hitting the bike frame. The BB will usually have its size printed on the cartridge, but you have to take it out to read the numbers. For example, a 68x116 bottom bracket is 58 mm wide as it fits into the frame, and the spindles are 116 mm apart. If you wanted the pedals a bit closer together, you might buy a 68x112.5 BB.
Sealed Bottom Bracket: If your bottom bracket is a sealed cartridge unit (as most are nowadays), it can't be serviced or adjusted. If it grinds, wobbles, or catches, it must be replaced as a unit. Just remove the old cartridge and replace the entire thing.
Take the chain off the chainrings, and lay it on the frame next to the bottom bracket. With the bike clamped in a workstand, shove the base of the crank-arms side-to-side to detect motion in the bottom bracket. Now try to pull the cranks away from, then back towards the bike to detect wobble. Turn the crank and listen for noises within the bottom bracket. These tests will help you identify a damaged bottom bracket.
To replace the bottom bracket, you have to do some major stripping! You must remove both the left crank and the right crank arm plus chainrings. See the crank section for additional information.
PLEASE click on the link directly for more help
http://www.utahmountainbiking.com/fix/bracket.htm
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Apr 02, 2010 | Ford F-150 Cars & Trucks
Cycling Logo
64 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
