Question about Dell Axim X3 Pocket PC
Axim x3 power switch light flashes green constantly
X3 power switch flashes green whether on or off. Remove battery and it stays off until unit is turned on, then it won't go off until battery is removed again. Any ideas to fix problem will be appreciated.
DonKF
  • DonKF May 31, 2008
    Problem resolved before I got your posting. System hung up so I disconnected the battery, left it out for about 20 minutesthen reconnected. The system rebooted and is acting normal now.
    The blue fashing light on the top right corner indicates the wireless is operating. Thanks for offering your assistance.
    DonKF
  • 4 Answers
Similar problem with Axim X50; green light for on-off switch flashing for no discernable reason. Took battery out and put back after about 10 seconds and problem remained; took battery out and waited a minute then put it back, problem disappeared.
Posted on Feb 29, 2012
  • 32 Answers
As far as I remember its the wireless working, if you press the button on the far right u can disable the wireless..this will turn off the flashing green light.
Posted on May 30, 2008
What if my new backup battery for my dell axim x3 wont charge
Usually a good indication that either A. the battery is bad even though you just purchased it or B. the battery is non compatible with the charger.
Jan 11, 2011 | Dell Axim X3 Pocket PC
My dell axim x30 backup battery needs replacing. Is this something I can do myself?
i believe if you are a bit of a hands on type of person you should be able to do this yourself.
but not without researching !
read this page, should tell you everything you need to know, from the perspective of someone who had to do the same changing of the CMOS battery.
http://www.mobilitysite.com/boards/x3-x3i-hardware-troubles/96005-x3-backup-battery-revealed.html
or read below:
quoted from: Tenc hi4U
DISCLAIMER : I take no responsibility for any damage you may cause to your Axim. The parts and proecedures described in this guide refelct my own experience with my own Backup Battery (BuB) in my girlfriend's Axim X3. Your mileage, parts, anbd experience may vary.
Tools needed for successful BuB replacement:
1. fine tip jeweler's screwdrivers (helpful if you slightly magnetize the tip)
2. Varta V20HR rechargeable NiMH battery
3. electrically conductive silver epoxy
4. strong needlenose pliers
5. electrical tape or heatshrink (razor blade or scissors to cut to shape)
But here it is step-by-step:
1. Pop little rubber caps from 4 corners of back covers. Disassemble Axim X3 with small jeweler's phillips head screqwdriver. Be sure to plave all parts in a plastic bag or other container (4 scres rear cover, 2 screws near port). Disconnect the ribbon connector towards the bottom of the PCB and the speaker wire (also on the lower portion of the PCB). Backup battery should be the green covered circular item under the pcb).
2. Locate backup battery, Cut away BuB cover, & CAREFULLY use strong needlenose pliers to grip and "roll" the leads off of BuB.Be very careful with the leads.
3. Mix dime sized batch of silver conductive epoxy (do NOT hot solder this battery, heat will lead to BuB damage and destroy lead connection to wire).
4. Apply epoxy to both sides (not too much)and afix respective leads to respective side (red lead goes to +, black lead goes to -). Secure connections with some type of clamp (I used a binder style paper clip, but a wooden close pin or something else that will hold the leads to the BuB while the epoxy cures (Mine took 24 hours to cure).
5. Recover new BuB with protective covering (I use electrical tape cut to the shape of the BuB. Covering WILL have to be form fitting to fit back into Axim BuB "slot".
6. Reassemble and charge Axim and charge.
Sep 07, 2009 | Dell Axim X30 Pocket PC
Windows Vista will not recognize dell axim X3
I have had that problem with other USB devices i suggest trying a different USB port as the USB port you have used to connect the X3 to is most likely malfunctioning.
Aug 10, 2009 | Dell Axim X3 Pocket PC
I have a pocket pc axim x3 ,i charge the battery but no turn on . how torn on the pc
Does the light come on while charging in the cradle? if so there is a power button where the light is. also try taking the battery out and putting it back in to see if that works
Jul 12, 2009 | Dell Axim X3 Pocket PC
Hello Experts, I have a second hand dell axim x3. I am trying to use internet. The X3 says I have a WiFi connection. But when I go to the internet of e mail, the x3 says that the page I am looking for can...
Have you set up the Connection properly on the X3?
As i have had a similar problem with the X30 i had to go through the network connections config and fiddle around with them until it connected properly. sorry i could not provide any specifics in this situation as it has been at least a month since i set it up.
Jul 10, 2009 | Dell Axim X3 Pocket PC
I'm getting a message - backup battery very low etc -
you can buy a Backup battery for the axim X3 series on Ebay for about 17.00 that includes shipping. best price Ive seen
Dec 05, 2008 | Dell Axim X3 Pocket PC
Axim X3 battery
ebay, I just changed mine. Make sure it has the plastic end on the P&N wires
Oct 28, 2008 | Dell Axim X3 Pocket PC
Dell Axim x3
The only place you can get this watch type battery with terminals attached is from the UK. Go to CPC.farnell.com The battery you need is made by Varta, the part number is 55902201012.
You can E-Mail ( sales@cpc.com.uk ) or ( Kayley.Davenport@cpc.co.uk ) They can give you a price. You will have to set up an account before you can order it. Then you have to E-transfer the money and they will ship it. It's about $9.00 each. + shipping. I didn't by one. decided not to fix my pda even though that's all that's wrong with it.
Feb 11, 2008 | Dell Axim X3 Pocket PC
Bad Display
it could be a corrupted battery pack
Nov 07, 2007 | Dell Axim X3 Pocket PC
Dell Axim X3 Pocket PC Logo
239 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
