Question about Simrad Rf300 Rudder Feedback 20193447
I need a RF300 rudder feed back for my AP22 - Simrad Rf300 Rudder Feedback 20193447
Raymarine 4000 + autopilot. I immediately get an RG Fail message when I engage the autopilot on my Catalina 320 Sailboat.
I am not familiar with your particular model autopilot, but I do know that Raymarine autopilots can be fussy. All must have a compatible gps feeding it, of course. All must have a rudder angle indicator if your auto pilot connects to the wheel or rudder instead of directly to the tiller.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Aug 25, 2017 | Raymarine Boating
Is there some way to (personally) drop the rudder sufficiently into the water for it to work properly? If so, how?
Hi Penny:
My experience with kayak rudders is that they can be raised and lowered by pulling on a cord attached to the rudder. Mine was secured by a bungee so that the cord lay flat on the deck but was easily accessed by reaching back.
With your kayak out of water, manually raise and lower the rudder and look at the assembly where it rotates. There should be holes there to accept cords as I described.
If all else fails, Go to a beach where there are other kayakers and ask to see theirs (rudders).
Jan 21, 2016 | Riot Kayaks Brittany 16.5 Skeg/Rudder
Spektrum dx6i rudder error
Hi you need a new rudder motor
Mar 22, 2014 | Spektrum Dx6i Computer Radio
MY SIMRAD AUTO pilot is telling me rudder error what is the problem is it the linear feed back cylinder
Has it ever worked?
What has changed?
Is it the a "pole/linear" or a "rotary" FB unit?
Out of the 5 basic parts of the AP system, the RFB is the most replaced due to the environment (Splash, heat, vibration, mech movemnet).
"Rudder feedback error"
does not see the RFB at all.
check the connections in the J-box first.
you should be able to manually turn your wheel and see the RFB indicator change on the control head.
"rudder responce error"
does not see the RFB move when the AP is given a command.
then check physical connections.
could be loose, could be backward?
Nov 28, 2010 | Simrad Lf3000 Linear Feedback 20188074...
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
Twist Rudder feature interferes with use of rudder pedals.
Ya you can disable it just go to menu of home page>Controls>assign A command> and disable
Jan 24, 2009 | Saitek ST290 Joystick
I AP 35 Setup
ensure you are setting correct rudder value.
Aug 14, 2008 | Simrad AP35 GPS Receiver
RayMarine wheel 4000
You would need to supply more info to pin point problem. 1) Do you have hydaulic steering?If so do you have a rudder feed back sensor. 2) Is this a new install or did the pilot work properly before 3) Do you have a smart pilot course computer in the system or is the wheel drive run straight from the head unit. 4)What was the deveation reading on your auto pilot compass when it was swang. 5)Was the pilot comissioned by a qualified person. I know there is a lot of questions here but there could be many things that are causing the S.Once the above questions are resolved I should be able to narrow it down to one or two things. Regards Robert
Aug 13, 2008 | Raymarine St 4000 Wheel Drive E12093
Rudder control
Your in luck I happen to be a Flight simmer also. You need to go into your main menu under settings in Flight sim 2002. You will see enable joystick then you will see cordinated flight or uncordinated flight. You want to select uncordinated flight. Meaning that you will have full control of rudder and the sim will no longer make coordinated turns for you. You will have to add rudder to prevent a skid.
Sep 19, 2007 | Saitek CYBORG EVO FORCE Joystick
Simrad Rf300 Rudder Feedback 20193447 Logo
Top Simrad Boating Experts
Steve
Steve
ray gallant
Don A
Don A
Are you a Simrad Boating Expert? Answer questions, earn points and help others
