Question about GE Washing Machines
I have a GE WCSE3100AOWW washer. Recently it has emitted an almost burning like odor during agitation or spin. WHat could be causing this burning smell? The performance of the machine is normal, at least as far as I can tell, but the smell reoccurs with each use. I have removed the drive belt, and the clutch/motor spin by hand in both directions, but the drive pulley only turns CCW (while looking up from the floor). The drive pulley does not turn CW (but does show some "play" in that direction)....is this normal? The drive belt does not looked scarred or burned. Your assistance is appreciated.
  • cynfinney Oct 10, 2010
    The first advice I received was difficult to follow...something about the power panel possibly emitting the smell. I would like other opinions.
    President:
  • 1,554 Answers
The machine's performance is apparently normal if it agitates, drains, spins, and gets clothes clean. The apparent locking up the drive pulley in the CW does not indicate any problem, that's normal. Otherwise, the machine will not work properly. The burning smell is coming from the motor itself that's why it reoccurs each time the machine is used. The motor is overheating, starting to go out, and may need to be replaced soon.
Posted on Oct 10, 2010
    Genius:
  • 1,417 Answers
What this indicate is that the panel of the washer has over gone some stress over time,the way that the washer can give sign to show it weakness is to bring out odor from the panel connected to the power supply or the motor connected tot he drum after some in agitation which might need a replacement or little service .
Hear are tip below for service.
what you are to do to solve this problem is to carefully unscrew the washer with screw driver (technician tools) then trace the main wire that supply power over to the washer it is connected to the panel and the control unit first clean up all form of liquid around the panel then note a you are do that is there is any form of damage from the panel or you cam get the odor from the it or not then you do same to the drum if you can not fine any from the panel
and if after this the problem remain then you will need to replace the panel
Please note you will hae to put off all form of power supply connected to the washer before carry out this home work.
Thanks and thanks for using fixya.
  • Oloyede Monsuru Oct 10, 2010
    hello,
    What this solution is about indicate to you that the problem can
    be view from two point
    1) from the panel i.e the power distributor on the control unit then,
    2) the rotor (motor) that spin the the drum
    The above solution will guild you on how to go about it,
    Hope this help?.
    Thanks once again.
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
It is leaking during the washing and ring but not the spin or drain
Check to see if the washer inner tub is spinning during the agitation. If it is it is causing the water to spin up and over the side during the wash cyle. Bad brake package and usually not worth repairing. You can also have too much high sudsing soap in your washer, causing it to over flow out the safety overflow pipe. Good Luck Appliance Specialists.
Dec 14, 2009 | GE Washing Machines
Burning electrical smell and the agitator will not spin on a GE S3700E
Check the condition of the drive belt.If worn badly you would sense the odor of the belt ningbur
Oct 18, 2009 | GE WBSR3140DW Top Load Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Maytag washer will not agitate. model pavt244aww
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
GE washer not agitating
when you pulled up agitator was the splined shaft moving back and forth ? If so replace the insert in the agitator. If not the problem is in the transmission .
Dec 11, 2008 | Washing Machines
GE Model wwsr3090t6aa Agitator problem
You probably have burning belt LOL.
Can you turn the agitator by hand at all?
If no, look for anything that may have gotten wedged under the agitator causing it to lock up.
If you can turn it a little. you most likely have a worn stretched belt or tensioner spring.
The only solution for that is to replace the belt or tensioner spring.
Dec 06, 2008 | Washing Machines
Washing Machines Logo
82 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
